Question about Video Cameras
What voltage is required for the adapter for this camera?
Posted by willie johnson on
  • Brad Brown Apr 19, 2016
    Hi willie johnson, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? what camera
Purchased a universal travel adapter. Can this be used in Cuba? Thank you for your help
What voltage and frequency does the device require you would be plugging in to the adapter ?
https://www.tripadvisor.com.au/Travel-g147270-c104286/Cuba:Caribbean:Electricity.html
You need to check the voltage matches between the device and the power point as the adapter does not change the voltage or the frequency. Some devices may not work if the frequency is required to be the same. like timing devices may not keep time if the frequency is different.
Jan 12, 2018 | Universal Computers & Internet
What is the power output of ac dc adapter in jensen jta 460? Can this adaptor be changed with 220volt ac dc adapter with required dc output?
For Any Adapter:
As long as the Voltage and Power output of the power supply (wall outlet or other) matches the input requirements for the adapter whether 110V or 220V.at enough amp output; and
IFF the dc output of the adapter is exactly the same voltage and has for amps at a minimum matches the maximum amperage requirement for the input of the device, any of them will work, as long as it has the right connector with the correct polarity needed for the device!
Or, in other words...
Supply Output V = Adapter Input V
and
Adapter Output V = Device V
Adapter Output A(min) >= Device A(max)
Aug 27, 2015 | Computers & Internet
I was having trouble with the "low battery"
If you used a voltage 3 times the required voltage then you have probably damaged the camera beyond repair. There may be a protection fuse on the circuit board inside but locating and fixing this would require an experienced electronics technician. i wouldn't hold out too much hope of getting this camera repaired.
May 24, 2011 | Samsung Digimax A7 Digital Camera
What size ac/dc adaptor do the dsc-s500 use lost mine [email protected]
You need this one:
Product Description
: Sony AC LS5K - power adapter
Product Type: Power adapter
Dimensions (WxDxH): 4.8 cm x 8.1 cm x 2.9 cm
Weight: 0.1 kg
Voltage Required: AC 100-240 V ( 50/60 Hz )
Voltage Provided: 4.2 V
Feb 02, 2010 | Sony Cyber-Shot DSC-S500 Digital Camera
AC adapter for a Halex dartboard #65040
Ac adapter for Halex can be found on amazon, click here and take a look: Amazon com halex dartboard ac adapter. Have a nice day
Jan 09, 2010 | Halex 64339 Match Play Electronic...
Replacment adaptor
Look at the old adapter if you have it. Match up the voltage requirement. and meet or exceed the current (mA) rating. also make sure it is DC if required. Any adapter that has the right voltage and current output will work. Also you can go over the voltage but like 20% ie: 12V works for 9V, and 15V works for 12V and so on. But if you go under the voltage requirement, only do so by 10 percent. And increse the current requirement proportionally. Chances are you have an old adapter around that you are not using. If you need to change the connector, the wire with the white stipe on it is usually positive. So long as you match them up you should be ok.
Dec 21, 2009 | Durabrand PDV-709
I need a power adapter for my nascar pc notebook.
The reason why the adapter is running extremely hot is that either it is faulty and it's capacity too low for your laptop requirements.
Check the voltage and current requirements of your laptop, it is printed on a label on the bottom ofthe laptop.
The power adapter you require should be the same voltage and current (amps) or higher current rating that what is printed on the laptop label.
Jan 07, 2009 | ZT Group NASCAR M2002 Notebook
Polaroid FLM-2011 LCD
look at the back of your lcd it usually will state the voltage and power requirements of the required replacement adapter...never exceed the voltage requirements this may cause damage DO NOT USE THE 16V ADAPTER!
The adapter you require appears to be rated at 12V x 5A a 60Watt unit you can replace most likely with similar switch mode unit rated at 12V and at least 5A or more
Aug 25, 2008 | Polaroid FLM-2011 Television
Camera lense
There is a very very easy way to fix this problem..
This can happen if...
1.) If the battery dies when the camera lens is open (and you close it manually, or sometimes, even if you dont.)
2.) If you used a AC adapter with too much voltage or not enough. (this can happen even if you used the correct voltage, refrain from using AC adapters at all)
... all together its ethier a voltage or camera lens problem...
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
Hopefully all this information helped,
May 05, 2008 | Minolta Vectis 2000 APS APS Point and...
My tablet is not pluging in
Toshiba computers have a label on the bottom that displays the exact voltage and minimum amperage required to power the computer ("DC15V 3.0A", for example, which means 15 volts DC (direct current), at 3.0 amps. Each Toshiba AC adapter has a label indicating its output voltage and amperage capacity (for example, "DC15V 3.0A"). Important considerations for using AC adapters with portable computers:
The connectors must be compatible -- they must mate together correctly.
The voltage level must match exactly (a computer designed to run from 15 volts can be powered only by an adapter rated to produce 15 volts). If the AC adapter's voltage is higher than the computer's requirement, the computer and the battery may be damaged, If the AC adapter's voltage is lower, the computer may not operate correctly, or not operate at all.
The AC adapter must supply at least enough amperage (current) to meet the computer's amperage requirement. Otherwise, the computer may not run properly, the battery may not charge correctly, or may charge very slowly.
The quality of the power (ripple, noise and other factors) provided by the AC adapter must be very high. AC adapters from other manufacturers may supply sufficient amperage at the correct voltage level but the quality of the power may be poor, which can cause the computer to operate erratically, and could even cause damage to the computer. Whenever possible, use the correct Toshiba AC adapter for your computer.
The computer's power light may blink to indicate that there's a problem with the power from the AC adapter.
Mar 25, 2008 | Computers & Internet
Video Cameras Logo
48 people viewed this question
Top Video Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Al Rush
Marvin
Marvin
Are you a Video Camera Expert? Answer questions, earn points and help others
