How to use an antenna box for more channels
I do not have cable; it is an amazon fire tv box. I want locals and other channels I can't stream for free. I bought an antenna box. can't figure out how to get the channels now!
Posted by Lori Allison on
Jerry Kramer
  • 3,904 Answers
Once the antenna is mounted and connected to the TV then you can go into setup menu and do a channel search. You will be prompted to set it up as CABLE or AIR/ANTENNA. Select ANTENNA and it will program all available channels for you.
Posted on Apr 19, 2016
I need code for digital stream box for a trinatron tv
Faq - digital stream technology, Inc. ( digital stream ...
www.dsconverter.com/index.php?p=5
Can I use my Universal Remote Control to operate the converter box? ... Do I need a special antenna to receive digital or high-definition TV? .... Note: If you want to reset the remote back to the beginning of the TV code list, clear the memory by ...
Installation - digital stream technology, Inc. ( digital stream ...
dsconverter.com/index.php?p=3
Connecting the DTV Converter Box to your Analog TV Set with RF cable · - Connecting the DTV Converter Box to your Analog TV Set with Audio/Video cable
Digital Stream Analog Pass-through DTV Converter Box
www.amazon.com/Digital-Stream.../B001TO3L8Y
Amazon.com, Inc.
Rating: 3.4 - ‎131 reviews
Digital Stream Converter Box Remote DTX9950 ... RCA DTA-800B1 Digital To Analog Pass-through TV Converter Box ... I think the bad capacitor is something like a 16 Volt capacitor, and you have to replace it with a ... remote(I was able to find the code for my old JC Penny TV), a seperate button for channel signal strength, ...
Amazon.com: Customer Reviews: Digital Stream Analog ...
Amazon.com, Inc.Digital Stream Analog Pass-through DTV Converter Box ... the code for my old JC Penny TV), a seperate button for channel signal strength, ... My brother somehow found out that there have been many of these Digital Stream boxes that were .... button that you can program into your tv (mine is a 1990's 11" Sony Trinitron).
Jan 14, 2016 | Sony FD Trinitron WEGA KV-32FS120 32" TV
After installing an outside antenna, our unit will not get streaming media.
Roku 101: everything you need to know about your Roku ...
https://blog.roku.com/.../roku-101-everything-you-need-to-kn...
Roku, Inc.Dec 22, 2011 - You will find in-depth posts on new channels, features and updates, and ... to stream your personal media from a laptop, desktop or media server. .... Alsomake sure your phone is connected to your home WiFi signal and not an outside one. .... The Sony unit seemed possible, but after watching the video I ...
Mohu Sky 60 Amplified Attic/Outdoor HDTV Antenna with ...
www.amazon.com/...Outdoor-Antenna/.../B00AVWK...
Amazon.com, Inc.Next step was to now get working on the install of the antenna, outside. ... Sat. that was outside, coax cable already run, and this Dish was not in use. ... I have MANY more pictures, it appears that Amazon will only allow up to 5? ... Three months after my initial purchase last year, the attic mounted MOHU Sky went dead. Well ...
Mohu Leaf 50 Amplified Indoor HDTV Antenna - Made in ...
Dec 21, 2015 | Televison & Video
Why will my new tv not pick up any channels when using the auto channel search
It depends on if you have cable or are using an antenna. If you have cable, make sure you have the cable that runs in between them hooked up to the correct spots. If you're using an antenna, you might need to get a TV converter box. A couple of years ago, they stopped making regular TV channels and switched to only digital channels. Most older TVs don't work with digital channels, so you need a box that will convert the picture. You can get one at any place that sells TVs (walmart, amazon, etc)
Feb 02, 2015 | Televison & Video
How do i get tv channels on my android tv box
In many cases these devices are not designed to pick up local tv stations. Instead they are designed to allow streaming of your movies and music from your computers or other network attached devices.
To get local stations you will need to ensure your tv is digital compatible (any tv made in the last few years will be) and then use the channel scan feature of your tv.
You may also need an additional external digital antenna to receive digital channels
Your android device can be used with an internet connection to watch youtube, amazon, (netflix on some devices) crackle, etc. These are internet services which usually can't be broadcast to a TV. So these boxes act in a similar way as the cable converter boxes of the 80-90's did.
Hope this helps you, feel free to ask further if needed.
Nov 17, 2014 | Televison & Video
I want to use an RCA F31224GG built in 1993 for OTA channels only. What type of converter/antenna do I need
You will need that converter box for the digital to analog system plus a out odf door antenna...radio shack is good place to ck...also ck out Amazon.com & eBAY
ck this outat Amazon.com http://tinyurl.com/m7xo528 for box
antenna here http://tinyurl.com/p2tsbra
Nov 13, 2013 | RCA Televison & Video
Hello, I am currently having a problem with my Audiosonic KM0767 Standard Definition Set Top Box. When we first bought it we wired up all the plugs and it worked great. We then moved onto Foxtel...
did you switch the TV's incoming signal to digital antenna? For the cable box it was probably set to cable antenna or analog inputs, not all TV's have automatic switching for antenna feeds. My Mitsubishi has 1 digital and 1 analog antenna input and the cable box will only work through the antenna input if it's the analog antenna input and it's tuned to channel 3 or 4, -(or through a seprate HDMI, PROSCAN, SVCR,or a yellow RCA plug input)- and when the analog antenna input is selected the TV will tune all analog cable channels that the cable service offers if a box is not used. likewise the TV will not tune any channels at all if it's set to digital antenna inputs. It will tune all local channels only when set to digital antenna inputs.
Dec 26, 2010 | Televison & Video
No signal onthe screen
If you are connected to a high definition cable box or satellite tv box you would not need to turn to channel 3 on your television. The television would need to be in the right input either component or hdmi. If someone connected the tv to the cable box or satellite tv box with a coax cable like an antenna cable then the tv channels will be available on channel 3 as well but they will not display in high definition. You change channels with the cable box/satellite tv box remote control. If the above is not correct and you are only connected to an antenna cable and not to a cable box or satellite tv box you will need to complete a channel search from the tv menu. It sounds like you are using a cable box/satellite tv box and that the tv is on the wrong input. If the cable box/satellite tv box is not working (i.e. just a black screen) on your television than that is a different matter entirely.
May 10, 2010 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Unable to pick up local ''free'' channels following digital change over. Using RCA DTA800 converter and Phillips 2750/27 antenna. Can pick up only one local channel, but signal loss is more often the...
first of all, make sure all your connections are secure and threaded all the way in. Next, go to the main menu and press 5 (configuration) and press 1 (search for channels) if this doesn't work, press 4(signal strength meter) and see how strong your signal is. You may just need to re-position your antennae. If all else fails try system reset(number 5) and repeat search for channels. I've had similiar experiences with mine but I have a 62% signal strength and still get 20-something channels. Hope this helps.
Oct 11, 2009 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
