Question about Sony Ericsson XPERIA X10 Cell Phone
How can I unlock my phone
0828234744
Posted by Mita Magdalena van... on
Nalin DSouza
    Guru:
  • 224 Answers
- Unlock all Sony Xperia 2010 Year (under test, private only)
- Unlock all Sony Xperia 2011 Year( with Test Point) (under test, private only)
- Flash All Sony Xperia/ Sony Mobile Android based mobile phones
- First in the World: Read Trim Area from Running OS via ADB( Android Debug Brigde, ADB - included)
- First in the World: Write Trim Area from Running OS via ADB (Android Debug Bridge, ADB - included)*
- Trim Area Backup Read using ADB/BootLoader(for test or Security reason)*
- Trim Area Backup Write using ADB/Bootloader**
- Single Trim Area element Read/Write*
* Not all TA elements can be written or read and not all Platforms support it.
** Not all TA elements can be written or read.
!!!Software require Internet Connection for all operations!!!
download tool
http://www.mediafire.com/download.php?7gede2no6nsccvd
Usage:
!!!IMPORTANT!!! Before any operation with any new phone - Back it UP! Later
you can restore it if somethings gone wrong.
A) To read/write Trim Area
using ADB:
1. Connect your phone to PC using USB Cable.
2. Enable USB-Debugging in Settings->Development menu
3. Install drivers
4. Go to TA work tab, click ADB in the software and press Connect.
If you need to Cancel you can click cancel to stop operation
5. Wait software to check root in your phone and try to root it.
6. If your phone is not rooted you recieve a message how to root
your phone.
7. Click Backup TA. All your TA will be backed up and saved in new
folder, same as your imei number
8. If you need to restore phone - click Write TA from Backup
9. If you need to read/write single element: enter element number in
heximal (for example 7da) and press read/write
9a. Upon write operation you will be asked to open the file to
write, so please be ready for this file to open.
using BootLoader:
1. Training: Connect phone in Flash mode (Hold the back (or the
Volume down in new 2012+ phones)) key and connect the USB cable.
2. Install drivers (x64 or x86)
3. Check if driver install ok
4. Disconnect phone
5. Go to TA Work tab and click Bootloader
6. Click Connect button. If you need to cancel you can click cancel
to stop operation
7. Connect phone in Flash mode (Hold the back (or the Volume down in
8. After successfull connect Click Backup TA (for your security)
9. If you need to restore click Write TA from Backup
10. If you need to read/write single element: enter element number
in heximal (for example 7da) and press read/write
10a. Upon write operation you will be asked to open the file to
B) To flash a S1_Boot android phone
1. Go to Flasher tab
2. Follow the procedure 1 of the read/write TA using BootLoader
(Traning)
3. Click Open firmware (acceptable formats: zipped firmware bundle,
with loader.sin inside), file format - zip or 7z (7-zip)
4. Select files to flash(eg. 1 file or All files)
5. Connect phone in Flash mode (Hold the back (or the Volume down in
6. Install Drivers (x64 or x86 - according your system OS)
7. Stand by, software detect phone and send the loader.sin from the
archive
8. Click Flash when phone is connected and software hint says "You
can press the Flash button now"
8a. Keep in mind, the system.sin takes longer at 99%, this is ok,
need wait.
C) To unlock phone
without Test Point (2010 phones only):
2. Install Drivers (x64 or x86 - according your system OS)
4. Disconnect phone
5. Enter your user id and password
6. Click unlock
8. Follow the on screen instructions (some phones require one or two
reboot).
with Test Point:
4. Disconnect phone
5. Connect the Test Point.
7. Keep the Test Point connected
8. Click Unlock
9. Stand by.
9a. Longer in description faster in process about 20 seconds.
Posted on Apr 21, 2016
Tip
General Mobile Unlocking FAQ
How do I unlock my phone?
At Unlock Zone we unlock phones using unlock codes. Every mobile phone has its own unique unlock code.
The method of entering unlock codes on your mobile phone vary from manufacturer to manufacturer and model to model. You can find unlocking instructions for your mobile phone by choosing your phone's model number in the supported phone models page on our website.
Will unlocking the phone remove my service provider's settings and logos?
No, unlocking your phone just removes the SIM card restriction on your phone so that you can use any other network's SIM card. It will not change the operator's settings and logos.
How does unlocking work in Unlock Zone?
Step-1 : Select an unlocking service which will work on your phone.
Step-2 : Submit your phone's details and make the payment.
Step-3 : Follow the easy step-by-step instructions we email you along with the unlock code as soon as it's ready.
How do I know if my phone can be unlocked?
Almost all GSM mobile phones can be unlocked. We however recommend you to visit the supported phone models page on our website and confirm that we have the unlocking instructions for your mobile phone.
Is unlocking legal?
Unlocking a mobile phone is legal in most countries. For more information about the laws and regulations on unlocking please click here, we also advice you to contact the respective officials in your country to find out more about sim lock laws and regulations.
on May 31, 2010 | Cell Phones
Can Q9c Motorola cell phone be unlocked?
If you want to unlock your Motorola Moto Q9c mobile phone from the network lock,I would suggest you to get an unlock code from Unlock Zone Unlocking the Motorola MOTO Q9C mobile phone at reasonable price and unlock it using the unlocking instructions given for your mobile phone from Mobile Unlock Guide .
Jan 20, 2014 | Motorola Mobility Moto Q9c Smartphone
My phone is unlock i want my phone unlock where i can get unlock code free
What is mobile phone brand and model ?If your Phone is an old model phone ,you can use free unlock code and unlock it..But if your Phone is latest Phone or I-phone you cannot get free unlock code or service to unlock it.You need to pay for getting unlocking service.You can buy unlock code for all latest phones at http://www.onlinegsmunlock.com/supported-phones/rs17wp7/ and unlock it.If it's an I-phone get remote unlock service there and unlock it easily. You can get free unlocking instructions here http://www.mobileunlockguide.com/
Jan 18, 2013 | NokiaFree Unlock Codes Calculator
Phone locked
What is Mobile phone brand and model?Do you need to unlock it from security lock or network lock.If you need to unlock your phone from security lock you can use default code ..If your phone is Nokia phone try 12345 or 0000 or 1234 these are default codes.For other phones get default code from online search...You need to unlock your phone from network lock ..you can use unlock code visit the site Prounlocking.com get the unlock code at reasonable cost and unlock it easily..If your phone is an I-phone you can get the Remote unlock service for i-phones from the site itself and unlock it very easily.....To unlock any phones step by step you can follow the unlocking instructions in the site.You can also get the unlocking instructions through email with unlock code or Unlocking service..Specify the network and country it is locked now , to get the unlock code or service ....
Oct 30, 2012 | Cell Phones
Need a unlock code for my samsung captivate
To Unlock Samsung Captivate from network lock use the Unlock code....Get the Unlock code from the site Onlinegsmunlock.com/unlock-your-phone/rs7wp2/
and Unlock it easily.
Jun 16, 2012 | Samsung Captivate Galaxy S At&t i897...
Iphone model MC143C unlock
You can Unlock the Phone and then Jailbreak it ......I will Clear the jailbreaking and Unlocking process...
Jailbreaking is important,Because without jailbreaking the Phone you cannot able install the third, party application ,you cannot connect to IOS ....So jailbreaking important,you can unlock then jailbreak the Phone...But unlocking is to remove the Network lock,,then only you can use any GSM Network Sim Card in the I-Phones,You cannot use CDMA Network in the Unlocked Phone,only GSM Network locked Phones can be unlocked,CDMA Network locked Phones cannot be Unlocked....Without unlocking you cannot use other Network Sim card,So unlocking is important,
You can Unlock the I-Phone 3GS using the remote I-Phone Unlock service,to get the remote I-Phone Unlock service you can reach the site Simpleunlocking.com and get the service and Unlock it...You need to install the I-tunes latest version in your apple i-phone 3GS to use that remote Unlock service.......All Network locked I-Phones cannot be Unlocked.So check service for Your Network locked Country,Network...then order service and Unlock it.(If you need to use Other Network than T-Mobile means You can unlock it)...
Nov 17, 2011 | Apple iPhone 3G
Need nck for alcatel e801to unlock the cell
To unlock Alcatel E801, go through the site http://www.prounlocking.com/unlock-your-phone/rs8wp2/
It has the best unlocking solutions.
Jul 26, 2010 | Alcatel E801A Cellular Phone
UNLOCK ALCATEL MOBILE PHONE
I unlock my Alcatel mobile from the site http://www.mobile-unlocker.com/
it has the best unlocking solutions.
Try this site and gain solutions.
Jun 19, 2010 | Alcatel Virgin Mobile ?£30 Text Cellular...
How to unlock a pantech duo c810
I have the code to unlock the Pantech C810 Duo mobile phone. Bur I donot know how to use or enter the code in the phone . Please guide me how to us ethe code to unlock the phone
Jun 18, 2008 | Pantech PG-3600 Cellular Phone
Sony Ericsson XPERIA X10 Cell Phone Logo
116 people viewed this question
Top Sony Ericsson Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Zaid Anarwala
Zaid Anarwala
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
