Tools & Hardware - Others Logo
Question about Staples Tools & Hardware - Others
Where do I find staples for the above Ace 2025 staples?
Posted by Maxine Wallace on
Vernon Taylor
  • Staples Master
  • 7,446 Answers
Most staple guns accept a range of staples of a standard type available from many different suppliers. It is rare that a staple should be manufactured for the exclusive use of a single staple gun.
First you need to know the sort of staple you need. Unfortunately staple gun manufacturers tend to omit this information from their literature and instead use the part number they have allocated rather than the more universal information of type and size.
Fortunately many nail and staple suppliers catalogues contain useful drawings with sizes so identifying any staple, once it has been very carefully measured, fairly simple.
Posted on Apr 19, 2016
5helpful
Can not find staples for 502 ace liner stapler ,
Hi, I found them on amazon, click here and take a look: Staples Undulated For 07020 Clipper Plier 5000 BX. I hope this was helpful. Cheers
6helpful
2answers
I have an ACE aircraft aluminum stapler... I bought Ace Heavy Duty Staples 3/8" 10mm Narrow Crown Arrow T50 staples but cannot get the arm to load with them on it.
Possibly you are trying to load it from the back with the arm out. This way does not work. With this stapler you must pull the arm out all the way and then drop the staplers in the bottom. Too easy, right? I felt like a dumb a$$ after fighting this one for an hour. By the way, it will take heavy duty staples but you need to match the item codes printed on the side of the stapler with the box at ACE hardware. Hope this helps... Say "yes" to "was this solution helpful?" so I can know that im not the only one who did this wrong :)
2helpful
I bought a used item #f509040 brad/staple gun (Air Ace) It came loaded with staples. How do I load nails??
The nails fit one side same place as the staples its usually on right side but may not matter. I hope this helps please rate if the answer helps in any way. Good Luck and have a great weekend.
Can't load staples in high capacity stapler
Try breaking off about 15 staples from the strip.
3helpful
Reloading ace 22084 staple gun
Hello there:
when you purchase staples for this particular gun even though you might get a staple that is says it fits this gun you need to look at the type of staple if you get the one that says heavy duty it will not work it took me 2 times to find out the right ones for this gun it comes in a green box and says standard duty on it not heavy duty this is where most people make their mistake. ok?
best regards michael
Can't remember how to load staples in my power shot stapler.
power shot guns have dif crown widths bring the gun to home depot or lowes and match them up or get the model # off the gun
tom
1helpful
2answers
Need help on how to put staples in Ace staple gun 22084
At the very botton of the stapeler in the back there should be a square mechanism press in and down then just slide the staples in and eplace the mechanism the way you took it out
Top Staples Tools & Hardware - Others Experts
Marvin
Marvin
Jesse Walters
Jesse Walters
Paul Bade
Are you a Staples Tool and Hardware - Other Expert? Answer questions, earn points and help others
