Hi
I have a Panasonic htb550 soundbar which no longer connects to the subwoofer
I have tried the reset,press remote input and main unit volume + to no effect
Any suggestions ?
Regards
Mark
These components are meant to be compatible with each other, providing a seamless audio and video experience. Here's how you can connect them:
Connections to the Media Center:a. Soundbar Connection: Connect the Bose Lifestyle 135 soundbar to the MC1 media center using an audio cable. Depending on the available ports on both the soundbar and media center, you might use an optical audio cable, coaxial audio cable, or another appropriate audio cable type.
b. Subwoofer Connection: The Bose Lifestyle 135 subwoofer is a wireless subwoofer, which means it connects wirelessly to the media center. During the initial setup process, the subwoofer should automatically pair with the media center. Follow the instructions in the user manual to ensure proper pairing.
Speaker Setup:
The Bose Lifestyle system, including the MC1 media center, typically uses Bose's ADAPTiQ audio calibration technology. This technology helps optimize the sound based on your room's acoustics and speaker placement. Run the ADAPTiQ calibration process as outlined in the user manual to ensure the best sound quality from your system.
Remote Control:
Ensure that the remote control provided with the Bose MC1 media center is properly programmed to control both the media center and the soundbar. If needed, follow the instructions in the user manual to set up the remote control for seamless operation of all components.
Audio and Video Sources:
Connect your audio and video sources (such as Blu-ray players, cable/satellite boxes, game consoles) to the appropriate inputs on the Bose MC1 media center. This allows you to route both audio and video signals through the media center and enjoy them with the soundbar and subwoofer.
Power On and Configuration:
Power on the Bose MC1 media center and ensure that the soundbar and subwoofer are also powered on. Navigate through the media center's on-screen menus to configure the audio settings, input sources, and any other preferences.
Testing and Adjustment:
Play different types of audio content to test the sound quality from the soundbar and subwoofer. Adjust the volume, bass, and other audio settings to your preference using the remote control and on-screen menus.
Remember to consult the user manuals for both the Bose MC1 media center and the Bose Lifestyle 135 soundbar for detailed setup instructions and troubleshooting tips. If you encounter any difficulties during the setup process, Bose customer support can also provide assistance.
It seems the best way to "remove code set" is to overwrite it with a different code set.
(From the Owner's manual for the Panasonic DMP-BD45)
STEP 6 :
Reprogramming the remote control
Change "Remote Control Code" (-> 28) on the main unit and
the remote control (the two must match) if you place other
Panasonic products close together and it responds to this
remote control.
You can operate the TV or amplifier/receiver using the unit's
remote control.
1 For televisions
Input the code (-> 37) with the numbered
buttons while pressing [? TV POWER].
For amplifiers/receivers
Input the code (->37) with the numbered
[RECEIVER j VOL].
e.g., 0001: [0] -> [0] ->[0] -> [1]
2 Test by turning on the television or
adjusting the volume of the amplifier/
receiver.
Great product, horrible instructions that focused on every language known to man rather than clear steps. Hope this helps....for the JAMO TORSTEN 2 WAY SOUNDBAR W/ WIRELESS 10" SUB 360 Series, as well as other Klipsch soundbars.
If the SoundBar is in STANDBY mode (solid RED status light), push the <SOURCE> button on the SoundBar until the status light is solid GREEN.
STEP ONE (Place the unit in learning mode): With the status light showing solid GREEN, press and hold the <SOURCE> and <MUTE> buttons on the front of the SoundBar at the same time (approximately 3 seconds) until the status light flashes RED and GREEN.
STEP TWO (Select the function to learn): Press the <MUTE> button once on the SoundBar (the status light changes to solid ORANGE).
STEP THREE (Learn the function): Hold your remote control within one foot and pointed at the front of the SoundBar. Slowly press the <MUTE> button on your remote control four times. On the first three presses, the status indicator light will flicker ORANGE with each press. If the unit has successfully learned the function, on the fourth press of the button, the light will flash GREEN several times and then turn to solid GREEN.
To program the remaining functions, simply repeat all steps, substituting <MUTE> with the new function and button presses (VOLUME UP, and VOLUME DOWN) on steps TWO and THREE.
I had just about given up on programming my Time Warner universal remote with my Boston Soundbar until a mental lightbulb came on. This is a two step process.
Step 1: Program your Time Warner remote (I have CLIKR-5, instructions available for other models at timewarner.com)
Using Pre-Programmed 3-digit Code method
-Turn on soundbar
- Press device button (I chose AUX) and OK/Select simultaneously until device button stays lit.
- Point remote control toward the soundbar and enter code (447 for Boston Acoustics)
- Press the device button again to store the code.
The TW instructions say you should now be able to turn the device off to verify that it works, but this is not true for the soundbar. Hang in there with me.
Step 2: Program your remote from the Boston Soundbar.
- Press the power button and the volume up button simultaneously until the indicator light flashes orange.
Here's where the instructions provided with the soundbar fail to explain how to do this. Each button is individually programmed into the TW remote. What you have done so far is enable the remote to accept the programming.
- Volume Up: press the volume up button on the soundbar while it is flashing, the light should become steadily orange.
- While holding the remote steady about a foot away from the soundbar, slowly press the volume up button on the TW remote four times. The orange light should flicker each time you do, turning green when completed.
- Volume Down, Mute, Power: repeat the steps for Volume Up, except press the button on the soundbar you wish program to the TW remote while the soundbar is flashing orange. It should become steady before you press the corresponding button on the TW remote.
Good luck, I hope this helps. -Deidre.
plug in the power to each unit with the provided power adapters, turn the sound bar and subwoofer on, activate the wireless subwoofer link by pressing a button on the soundbar (or remote) and subwoofer, and connect an audio source to either the provided analog or digital audio inputs on the soundbar Note: When using the Digital Optical input, set source device audio out to PCM
(you can hook to ur tv if it has a R/L audio output, or u can also connect it if your tv has a toslink style digital output. (most LCD and Plasma TV's have them.))
