Question about Vector Camping, Backpacking & Hiking
How long does it take to fully charge a vector smart battery charger? When I unplug it, it won't power on unless it is plugged in. it is a VEC 1092 a model
What is the error code f03 on the vector 1092 bettery charger
F03 - Sulfate or Unchargeable Battery
Appears when the battery is highly sulfated and cannot accept normal charge current.
• Follow the steps in "Recondition Mode" to recondition the battery.
• Follow the steps in "Equalizing" to equalize the battery.
• If the situation persists after reconditioning and equalizing, we recommend taking your battery to a certified automotive service center for evaluation
Aug 17, 2016 | Vector Camping, Backpacking & Hiking
How would I go about getting a charger
Depend on what kind of batteries, and how often you are going to use the charger, and for what purpose are going to use it.
If your battery accidentally discharge far from your home a Jump Start is a must. But Car batteries are shallow Cycle and need to be fully charged. If you want to Set and Forget Charger, then a Smart Charger takes care on his one for the battery. Automatically adjust the voltage and turns off when the charge is completed. Has the Reconditioning option, can display the battery voltage, and can check the alternator. Destroying a $120 battery is more expensive than a Smart Charger.
I use a Vector Smart Battery Charger - 2/10/20 AMP 12V fully automatic.
Retail $49.95 I bought on sale CLEARANCE: $29.95
If you have cars not driven in daily bases, or go in vacation, a battery Tender is a good option too.
May 20, 2015 | Vehicle Parts & Accessories
Where can I order a replacement charger for vector trailtracker sport lantern/weather radio model VEC 1198POB
If charger can be taken apart and the battery removed, try Batteryspec.com for a replacement battery. Worked for my Vector.
Aug 15, 2013 | Black & Decker 50 Watt Electromate with...
Vec 1097 A battery charger always give cod F03 with any battery
The battery in question so bad it wouldn't even register on the charger unit to any degree. I know this makes no sense, and kinda negates the whole point of even having a battery charger to begin with, but I learned of the battery it's attached to is too bad it won't even allow you to do ANYTHING with it.
Dec 06, 2012 | JUMP START SYSTEM
I purchased a Pronto 41 wheelchair and a Winsunny battery charger. The charger didn't have a manual so I'm wondering what the best procedure is for recharging the batteries. Do I need to turn the...
Joe See my tips on charging batteries No you don't have to leave the chair on when charging. Charge overnite after using it during the day. Always have the charger off when plugging it into the chair and unplugging from the chair. The charger you have doesn't have an on/off switch so get a power strip with the on/off switch, plug that into the wall and plug your charger into the strip use the switch on the strip to turn the charger on and off this will save you having to plug and unplug the charger rom the wall. Always store or put the chair up fully charged. If you don't use the cair daily charge at least once a week. It takes 9-10 chargings to get the batteries operating at 100% so use the chair and charge overnight while you sleep Never leave the charger on the chair more than 12 hours Hope this helps you
May 30, 2011 | Electric Mobility Pronto M41 Power Chair...
When charging my jazzy, do I unplug any plugs that controls my jazzy, or leave all plugged in? the reaon ask, green light will not come on the charger, which is onboard charger, unless I unplug controller...
No JJR all the plugs need to remain plugged in. On the Pride chairs the light on the charger will only come on green when the batteries are fully charged. When you unplug the controller the charger thinks the batteries are fully charged and the light comes on. Now the problem is the batteries. If they are old or you have a bad battery then the charger never senses a full charge so no green light. Hope this helps
Aug 26, 2010 | Pride Jazzy Select 6 Indoor Power...
Bad battery ???
It sounds like the battery has just enough "juice" to give the small light some power, but when the larger light is turned on it overloads the bad (or expired) battery. When you put a new battery in you can extend the life by not using the light when the battery starts to die. This is when it starts to permanently damage the battery. Turn it off and recharge as soon as it dims. Charge often, but don't leave on the charger too long unless it is a smart charger and turns off when the battery is fully charged. This will also reduce the life. You can find a replacement battery here: http://batteryinternational.com/spotlight-batteries-vector-battery.html
Jan 16, 2009 | Camping, Backpacking & Hiking
LOST AC CORD TO RECHARGE THE VECTOR VEC-157
u can get the cord from  radioshack just order 1 online for you.
Dec 30, 2008 | Vector 20 Million Power Series Spotlight
I need to find replacement ground (thumb screw) for vector 024
ground it off on the case...any grounding method should work. Unless you are talking about the main connection terminals... then just replace the missing thumb screw with a short screw and an eyelette type connecter.
Nov 18, 2008 | Vector VEC 024 400-Watt Power Inverter...
Camping, Backpacking & Hiking Logo
786 people viewed this question
Top Vector Camping, Backpacking & Hiking Experts
Marvin
Marvin
Lawrence Oravetz
Vernon Taylor
Are you a Vector Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
