Question about Refrigerators
My ice maker keeps on getting clogged up and won't dump ice!!! Is there something I can do to correct this?
Posted by kdzkirkpatri on
Happy Valley Air Care LLC
    Novelist:
  • 199 Answers
The most common cause for this problem is setting the freezer temperature to low. If digital, set to5 degrees, if rotating thermostat, set mid scale (example 0 to 7, set to 5)
Setting temperature to low causes the dispensing flap to frost up to not close properly after dispensing. If it does not close even more frost forms and ice starts slumping together causing ice to jam.
Hope this helps!
Posted on Apr 20, 2016
Amana refrigerator ice maker
There's a temperature sensor that turns on the heat element long enough for the ice maker to dump the ice. If it fails it will stop dumping ice.
Aug 21, 2014 | Refrigerators
Kenmore 106.55242400 ice maker knocking noise
most likely you need a new ice maker,one thing that could do this is the white arms that spin around when dumping the ice,sometimes one of the arms bend and jam the ice maker and you'll hear that knocking soundthe arm gets bent,the ice cube gets stuck because the arm can't push it out,,it stops the motor from spinning through it's full cycle and damages it but this is just a guess from something i've seen happen but most likely you need a new ice maker,one other i've seen is the metal arm that you can lift up to shut off the ice maker gets knocked out of the hole it slides into.if you pop off the white cover and get a jumper wire and stick it into the h and t holes you can jump start the ice maker.http://appliantology.org/gallery/image/659-manual-harvest-on-a-whirlpool-modular-ice-maker/
Jan 02, 2014 | Whirlpool Refrigerators
Manitowoc ice maker
sounds like your dump valve is stuck
Nov 09, 2013 | Kitchen Appliances - Others
I have a whrilpool refrigerater the ice maker will not fill with water?
Bonjour,
Ice makers can clog. The water valve can stick open or closed or even not work at all. The water fill nozzle can clog with ice or food. If the unit has been moved the water line could be kinked or the water filter may be clogged. Maybe the water valve for the ice maker water line is turned off. Is there one under the sink? Inside most ice makers there is a thermostat that tells the ice maker that the water is frozen and it's time to dump the ice cubes. That starts a geared motor running to dump out the cubes. And in some cases a mold heater is turned on to help break the ice cubes loose. A lot of ice makers have a cam attached to the motor that turns with the shaft. When the ice cubes are gone the cam starts a timer to refill the ice maker with fresh water to make some more ice cubes. Most "fill" cycles of ice makers are "timed fill". The fill cycle has to start and stop to get fresh water into the ice maker. There may be another thermostat that monitors the air temperature where the ice maker is mounted. If that thermostat thinks the air is not cold enough to freeze water nothing happens. If all the steps don't happen at the right time no ice cubes are made.
Jul 11, 2012 | Refrigerators
Our automatic ice maker will not quit dripping in the freezer. It keeps clogging the ice maker with icicles and large blocks of ice. Essentially, it keeps "freezing over." We have defrosted it...
if it keeps filling and overflowing you have a bad water valve on the back of the fridge.the part number is WR57X10027 and the valve is around 75 dollars.first thing lift the arm or shut off the ice maker so it won't leak anymore,you're missing a few letters off of the model number so when you call your parts store give them the full model number,open the fridge door,look up on the right hand side wall up near the ceiling and give them the model number to make sure you get the correct valve,shut off the water supply to the fridge,then have the new valve next to the old valve when you remove a water line from the old valve just connect it to the new valve,do this until everything is changed out and the new valve is in place,turn on the water supply and you can check the ice maker to make sure it doesn't overflow.you can manually start the ice maker by grabbing the plastic arms of the ice maker and pull them forwards slowly until the arms start to advance on their own,you'll hear the water valve fill the ice maker and then you can watch it fill to see if the water is filling it correctly and i'm sure you'll be fine with the new water valve installed
Jun 05, 2011 | GE Monogram ZDI15C Automatic Icemaker
GE side x side When ice maker switch is on, freezer warms up
It sounds like the ice maker is stuck in the harvest ( dump ) mode , in the area of mold heater activation . This area , heats up the ice mold to unfreeze the cubes , and keeps rotating to dump the cubes . This heater , gets hot enough to actually burn you if you touch the mold .
I would remove the 2 screws holding the ice maker , unplug from the ice maker receptical , and replace the ice maker .
Oct 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
No ice
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will make the switch to start the cycle.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Aug 19, 2009 | Refrigerators
Refrigerator will not dump ice.
I hate ice makers. Try putting a glass or something to keep the bar from going all the way down.
Apr 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker not dumping ice
Make sure the freezer is at least 17 degrees or colder (colder is better). If you have a square cover on the end of the ice maker see if you can pull it off and press on the gear face (don't turn just press). That may clean the electrical contact springs and get it working again. Basically if ya got water, 17 degrees or colder you will get ice. Other than that the ice maker motor module is likely bad (broken gear, etc.). Pretty common.
Aug 17, 2006 | Frigidaire FRS26KF5C Side by Side...
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
