Question about Pride Revo 3 Wheel Scooter
Status button flashes 5 times. Scooter is fully powered but will not move. Brake is off, lights work, etc.
Posted by Helen Sliker on
Jeff Bird
  • Pride Master
  • 1,345 Answers
BEFORE U RING TRY THIS TAKE KEY OUT PUT FREE WHEEL LEVER IN FREE WHEEL THEN PUT IT IN DRIVE PUT KEY IN & TRY OT. Hi again get in touch with pride www.pridemobility.com or ring them 1-800-800-8586. They might B ABLE to help cheers if the electronics r the same as celebrity put freewheel lever in drive & remove key then :::: put it back & try it out good luck
Posted on Apr 18, 2016
Testimonial: "Yeah, tried that with no result."
The error lite on Buzzaround Lite scooter flashing
5 flash code is the electro magnetic Brake. This is referring to the brake on the motor that can be released by the freewheel lever.
1. place the freewheel lever into the free wheel position. Ensure the scooter is in free wheel and move the scooter forwards and backwards a few times.
2. Place the freewheel lever in drive position, push on scooter to ensure it is in drive and does not move. Turn on key and press the throttle. If you have the same code again, call a technician to check the brake, chances are it needs replaced.
Aug 25, 2014 | Health & Beauty
Power light on revo power scooter blinks 5 times and scooter won't move
hi , that's a brake issue , check the microswitch located on the brake , check the wiring connection to the brake and then the resistance, about 30 to 60 ohms ...
Regards
Rob
www.gewizrepairs.co.uk
Jun 15, 2014 | Pride Value Line Revo Scooter 3 Wheel
Aquasoothe travelite scooter, the batteries are fully charged, the battery gauge is showing full, but the battery light is flashing. It flashes 7 times then pauses, we can't get the machine to move or...
Response to similar query in 2011.
http://www.fixya.com/support/t5751777-aquasoothe_travel_lite_instruction
not my words. The link to the pdf for this is http://www.discovermymobility.com/store/scooters/summit-scooters/elite-portable-scooter/manual.pdf
you want page 22.
Problem Check Point
The driving of the wheelchair is too slow or insufficient, the status
indicator lamp flashes slowly Batteries are exhausted and need to be recharged
1 flash The battery needs charging or there is a bad connection to the battery. Check the connections to the battery or charge batteries.
2 flashes There is a bad connection to the motor.
Check all connections between the motor and the controller.
3 flashes The motor has a short circuit to a battery connection.
4 flashes Freewheel is engaged.
5 flashes Not used.
6 flashes The controller is being inhibited from driving; this may be because the battery charger is connected.
7 flashes A throttle fault is indicated. Make sure that the throttle is in the rest position before switching on the scooter
8 flashes A controller fault is indicated. Make sure the controller connections are secure.
9 flashes The parking brakes have a bad connection. Check the parking brake and motor connections. Make sure the controller connections are secure.
The-Active-Light
does not function,
the Battery/
Status indicator
flashes rapidly.
Count the number
of flashes:
10 flashes
An excessive voltage has been applied
to the controller. This is usually caused
by a poor battery connection. Check the
battery packs and controller
connections.
Sorry wasn't sure how much space they give you for answers. :)
Oct 11, 2013 | Health & Beauty
We have fully charged the battery but when we pull the paddle to move it doesn't go
Reengage the wheels again then give it a slit push you should fell some resistance .seems the freewheel is not fully in
Apr 24, 2013 | Electric Mobility Mobility Electric Power...
Celebrityx scooter blinks 5 pause 5 everytime i turn key on
Either your parking brake is engaged or if your scooter is more like mine i have a Rascal 600t it gives a code 5 service code when it thinks its in free wheel. The freewheel mechanism is located on the trans-axle which if you go outside across grass it gets wet. This device doesn't like moister and will get stiff will partially engage or disengage. In that mechanism there is a micro-switch which if the lever when slipped into the engaged position doesn't go all the way to the seated position the switch will see the mechanism as being disengaged [in free wheel] and will inhibit the motor from running. I lubricate the entire assembly with pure silicon spray oil,WARNING, do not use WD-40, It will eat some plastics.After lubricating the lever should move smoothly. I have to lub my scooter about once a month in the winter.
Now if this doesn't work check the connector that are all the wires are connected. Disconnect the connector check the pins are ok reconnect check to see if your still getting the failure. If you are still getting this problem do continuity checks on the wiring. You will need a multimeter only $9
http://www.amazon.com/Mastech-YG188-Pocket-size-analog-multimeter/dp/B00064CH6A/ref=sr_1_8?s=hi&ie=UTF8&qid=1339024102&sr=1-8 Check the switch in the freewheel assembly. Select ohms the highest scale, short the leads together, zero the meter by turning the zero adjust knob. There is only one wire we are interested in. On some scooters you can visually see the switch and the wire running from it. The wire usually goes to a spade connector. Disconnect the spade connector put a probe on that connector leading to the switch. Disconnect the battery put other probe on the positive side of the terminals that were connected to the battery not to the battery it side.Work the switch does the meter needle deflect to zero, no, try the negative side. Does the meter deflect, no, put the probes directly on the switch terminals, does the switch.when worked now cause the meter to deflect, no, replace switch, yes, the problem is in the harness, don't panic, use can use that meter to trace the wire through the harness. Wiggling wires and flexing connectors usually makes the meter flick at some point. Thats how i do it i'm never without my trusty meter. My scooter a Rascal are notorious for having problems of this type my mid-frame harness fell apart in the middle of a six lane intersection, the scooter simply locks up tight .I can do nothing but sit in the middle of this huge intersection. People try to move me but the scooters wheels are locked, my illness makes it so i can't communicate with people, it was a mess. So i modified the connector so its no longer a latch type connector. I drilled it for a quick pin which is much stronger than what its using now. Hope this helps
Jul 05, 2012 | Pride Celebrity X 4-Wheel Electric Scooter...
I have an electric mobility scooter 302Le that is fully charged but will not run. The lights and horn all work but the scooter will not move. The led light in the control box flashes five times. Can you...
Barb the flashes indicate a brake problem. Make sure that you aren't in freewheel. Move the freewheel lever located at the rear of your scooter up and down a few times then put it in drive mode and turn the scooter on and see if you still get 5 flashes If so you will have to replace the brake assembly Hope this helps
Oct 20, 2010 | Health & Beauty
Controller light is flashing and chair will not move
Sandi Count the number of flashes ie: 4 flashes pause 4 flashes pause etc. This will give you the flash error code and your users manual should tell you what the number of flashes indicate. (for example 3 flashes bad brake) Also check to make sure your scooter is not in freewheel. Turn off the scooter and move the freewheel lever in and out of gear a few times then turn the scooter on and see if you still get the flashes. If you can't figure out what is wrong then contact your provider and ask if they can check it out for you. Hope this Helps
Oct 03, 2010 | Pride Go Chair Travel Power Chair
I have a golden companion scooter and it wont move it flashes a green light but i haave no info on where to obtain the trouble codes
The L.E.D. located on the tiller
dashboard will indicate with flash codes what problem is occurring.
L.E.D. Flashes 1 time and pauses, 1 time and pauses…. Batteries are low,
scooter will still operate.
L.E.D. Flashes 2 times and pauses, 2 times and pauses…. Batteries are very
low, scooter will not operate.
L.E.D. Flashes 3 times and pauses, 3 times and pauses….Over voltage to
controller.
L.E.D. Flashes 5 times and pauses, 5 times and pauses….Brake is in the
freewheel position or connection to brake is open.
L.E.D. Flashes 6 times and pauses, 6 times and pauses….Paddle or speed
potentiometer problem.
L.E.D. Flashes 7 times and pauses, 7 times and pauses….Paddle or speed
L.E.D. Flashes 8 times and pauses, 8 times and pauses….Motor
disconnected or faulty.
L.E.D. Flashes 9 times and pauses, 9 times and pause….Controller fault.
I hope this helps they are pretty standard codes I got this from Golden Tech Web Site
Aug 17, 2010 | Golden Technologies Golden CompanioN II -...
Pride Revo 3 Wheel Scooter Logo
727 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
