Oct 16, 2007 - 31 posts - 26 authors
Learn more about Ford Windstar at the Edmunds.com Car Forums! ... Then on Friday it died while I was driving down the street. ... I have a 3.8L v6 1996 Ford Windstar. .... Then yesterday the car just died while driving and had to be towed back to .... The engine will crank, start run about 5 seconds then stop.
? 3:59
https://www.youtube.com/watch?v=zwlruD4JXmY
Jul 20, 2010 - Uploaded by Scotty Kilmer
Fixing A Car That Randomly Dies While Driving. Scotty Kilmer ...Just check it out at https://www.youtube.com ...
The 2002 Ford Windstar has 11 complaints for engine stalls/shuts down while driving. ... 2002 Windstar just starting shutting off in the middle of driving. ... The engine diesupon acceleration and will crank but won't start unless switch is ... Inspected the Fuel Pump shut-off Switch, Fuel Filter, Run several full tanks of gas ...
I would guess that something inside of the transmission has failed and there is no longer a mechanical connection between the motor and the drive axles regardless of what gear you attempt to move in.[sheared splines, broken planetary, etc.] Often when this happens you won't hear any kind of noise because of the failed parts being inside the transmission case...instead the car just won't go anymore. You could have a CV drive axle joint that has failed but generally they will make some noticable rattling or grinding noise as they churn away when you try to go forward or reverse. If something has failed inside of the transmission then the transmission will need to be removed and repaired. It if is just a drive axle joint that has failed then that can be replaced without doing anything to the transmission. Hope this helps and good luck!
check your fuses. then check them again. check your air filter. if its clogged , truck wont start. fuel filter clogged up ? out of gas? battery dead. starter went out ? ignition parts went bad. too many things could be wrong. try to eliminate some of them by posting more details.
My sincere apologies for the delayed response. I am personally going back to answer your unanswered questions. I do not know if you still need this information, but I am going ahead and answering it anyway. You may want to Print the Diagrams for future use.
then the transmission has failed or has sticking engagement solenoid in trans pan, have the fluid and filter replaced and see if that corrects the problem
