Question about Princeton Digital VL173 Monitor
How to unlock buttons?
This is an old monitor; using it as a second display for my Mac. Can't change contrast or brightness, also cannot use power button. Current contrast & brightness need to be adjusted.
    Habit-Forming:
    New Friend:
  • 70 Answers
Not sure if this is exactly the same as yours your model hard to find I had 2 similar monitors at previous employer and they both operated the same way Taking a Look 1. Power Switch Pressing this button turns the display system power on or off. 2. Menu/Select ? Pressing this button pops up the OSD menus on the screen, and used to select ("Up" direction) the OSD control options on the screen. ? This button is used to select ("Down" direction) the OSD control options on 3. Select the screen. 4. + This button is used to increase the value of the selected OSD control option. 5. 0 This button is used to decrease the value of the selected OSD control option. Quick Adjustment Function When the OSD Menu is not active, the following functions are available for the quick adjustment. Pressing ? button once pops up the OSD Function Main Menu . Pressing ? button once pops up the small Brightness icon. Use +or 0button to adjust the Brightness level. Pressing + button once pops up the small Volume icon. Use +or 0 button to adjust the Volume level.
If you need further help, reach me via phone at https://www.6ya.com/expert/richard_b70d968cd1a1d293
Posted on Apr 18, 2016
6ya staff
SOURCE:
How can I decrease brightness and contrast?
To help you change the brightness and contrast settings from the LCD monitor, please follow the instructions mentioned below,
The control buttons are located at front panel of the monitor. The Brightness Button is used to select the Brightness/Contrast adjust functions. Press to switch functions or adjust settings.
To decrease the brightness or contrast press (-) button & to increase (+) as per your adjustment.
GuruAid.com
Mar 29, 2016 | Dell E173FP 17" LCD Monitor
Change brightness
The second button from the left on the bottom corner by the power button is the brightness button. If you press it the brightness menu is pop up on the screen. With the menu up you just use the three buttons on the left to select the function and the increase or decrease the brightness and contrast on the monitor.
BuddyMc
Aug 07, 2013 | Dell E178FP 17 inch LCD Monitor
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
Brightness and contrast symbols
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
"OSD LOCKED" box on my screen
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
OSD stands for "On Screen Display." It is an onscreen configuration menu included with various monitors. When you press the MENU button or one of the other buttons on the front or side of a monitor, the onscreen display may appear. The OSD typically includes monitor calibration options, such as brightness, contrast, and color adjustments. Some OSDs may also include horizontal and vertical position controls as well as tilt and keystone adjustments.
If you can't make adjustments to the monitor settings using the OSD interface, the onscreen display may be locked. You may also see the phrase "OSD Locked" appear when you try to change the settings. Some monitors include an option within the menu called "OSD Lock", which you can turn on or off. If this option is available, simply turn OSD Lock off and you will be able to make adjustments to the settings.
If your monitor does not include the "OSD Lock" option, you may be able to unlock the OSD by pressing and holding the MENU button on the front or side of the monitor for several seconds. If you try this method, be patient! It may take up to 15 seconds for the OSD to unlock.
VOTE ME
Dec 07, 2010 | Dell Computers & Internet
Brightness/contrast menu popup
Sound like either the button is stuck or the display is in error.
press and wiggle the buttons carefully, and disconnect the power to the display.
Feb 02, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Monitor is control locked
you did not given details of model, company complet discreption of problem ok no problem you press the four keys on the monitor for five seconds simultaneusly or till it will show the massage "keys unlocked" then release
Nov 23, 2008 | Compaq P 70 Monitor
OSD Locked
Press menu button for 5 seconds until the text "OSD Unlocked" appears on the screen.
Aug 28, 2007 | LG Flatron L1750S 17" LCD Monitor
Monitor displays "Controls Locked"
This is a "feature" they include to prevent accidental changes to the screen setup. You should be able to unlock the OSD by pushing the Menu button and the right arrow button together for about three seconds. The message "controls unlocked" should appear. Let us know if you have any other questions and please don't forget to rate the posting.
Jan 31, 2007 | LG Flatron L1715S 17" LCD Monitor
Computers & Internet Logo
108 people viewed this question
Top Princeton Digital Computers & Internet Experts
Ekse
Eric Rotmil
Eric Rotmil
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
