Question about iPhone Apps
My Apple iPad voice goes how does that happen?
Posted by Reagan pereira on
1 Related Answer
bduxbury
Brett Duxbury
  • 4290 Answers
SOURCE: My first generation iPad appears to be totally dead. When I plug it into charge all I see is the flashing Apple. Is there a way to get the system going again ?
The battery in it has most likely expired and may cost more than a new iPad to replace. A voltmeter across the charger or a friends iPad may be useful to test your charger works ok.
Posted on Oct 11, 2015
Oct 11, 2015 | Apple Tablets & eReaders
Revert my ipad to original settings
To reset your iPad, just press the on / off switch (on top of the iPad) and the home button (in the centre on the bottom) simultaneous and wait till the screen goes blank and the apple loge appears. Then you can release both buttons. Wait till the apple logo is gone and 10 seconds later you can switch on the iPad with the on / off button.
That should be enough.
If this does not work like you expect, see what Apple has to say to do a "deeper" (Factory) reset. Be aware you will lose all data. When you do connect the iPad to your computer regularly and you have a backup in iTunes, this is great, because you then can restore everything like it was last time you connected to the computer. Turn your iOS device off and on restart and reset
Oct 10, 2014 | Apple iPad Tablets & eReaders
Ipad has voice over only when turned on..blank screen
Triple click the home button. Then double tap the VoiceOver off button. This should allow the device to return to normal operation. Then you can reset by pressing and holding both buttons (power and home) until it resets if you need to.
Aug 23, 2014 | Apple iPad 32 GB WiFi Tablet PC
Ipad troubleshooting
I think You have voice over feature turned on.
Open settings, than open general, than open accessibility than turn off Voice over.
Apr 01, 2014 | Apple iPad 64 GB WiFi
IPad shuts down itself
It seems that you've already tried reset (holding the home and power buttons, right?) the iPad and it does not work.
So you may need to connect your iPad to your computer and do a factory restore using iTunes.
Check this: http://support.apple.com/kb/HT1414
Jul 18, 2012 | Apple iPad 32 GB WiFi Tablet PC
"My ipad scren flahes occaisionally, should I be
Try doing a hard reset by holding down the home button and the sleep/wake button until you see the apple logo. If the screen continues to flash it is most likely a hardware problem and you should contact Apple to replace the device.
Apple Customer Support
http://www.apple.com/support/contact/
Sep 02, 2011 | Apple iPad 2 WiFi Black (MC769LLA) Tablet...
My Ipad is dead
If your iPad is in Manufacturing Warranty, please take it to the nearest Apple Retail Store and they will look into it. If you don't want to goto Apple, but want help from me, please explain what exactly happened before your iPad is dead. Accordingly i may help you.
Sep 15, 2010 | Apple iPad (16 GB) WiFi Tablet PC
iPhone Apps Logo
477 people viewed this question
Top Apps Experts
Marvin
Marvin
Harrie
ray gallant
Are you an App Expert? Answer questions, earn points and help others
