SOURCE: Miele Washer problem Novotronic Premier
Main wash light flashing is a heating fault. You either have a faulty temp sensor (NTC) or the pressure chamber has blocked and the heater element has popped.
SOURCE: Miele W864 Fault
I have a W844 and the exact same fault occured. I traced it to badly worn brushes on the motor.
SOURCE: my miele w842 starts its programme and then the
Firstly check the brush module is correctly located this can be done with a multimeter. you should get continuity between sets of pins. first pin on right of module is earth moving to left next two are the overload(continuity) next three are field coil windings(continuity between at least 2 out of 3 spin speed dependent) next two are brushes(continuity) next two are the tacho.(500 ohms) If this checks out OK. Then most likely you require new power electronic which clips on the back of control electronic
SOURCE: starts ok then skips programmes lights flash then
starts ok then skips programmes lights flash then stops without finishing wont complete any programme
