Question about Nikon D Cameras
My camera reads No SD card inserted...but i have
Posted by Kitty Gitulli on
brian92861
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 46 Answers
Format the SD card first.
Posted on Apr 17, 2016
Why is my camera reading err sd when I insert sd card
I can think of a few possible issues:
1. SD card not formatted (format it in the camera)
2. SD card bad. try another one.
3. SD card bigger than camera can handle.
Sep 16, 2014 | Wildgame Innovations IR4c Digital Game...
It displays a card error message when i insert an sd card.help please.
You have to check out that if your camera support your SD card(type, capacity size ) or if there is real something wrong with the card. Using a card reader insert to PC and see if the card can be read, if it's OK, formatting it by PC then insert it back to camera and see if the problem can be solved. Else, If the card can't be read by PC you only have to change it.
Apr 27, 2011 | Cameras
I have a jazz DVX50. The problem that I am having is I inserted the SD card and all it will keep reading is read card...
It is possible the card as become corrupted a common problem with cheaper SD cards.
2 Soulutions
1 Try reformatting the card in your pc by following the directions on the website below
http://www.ehow.com/how_4793481_reformat-sd-card.html
2 Unfortunately you may need a new card
Apr 07, 2011 | Jazz Video Cameras
My Lumix DMC ZS7 reads "insert sd card again" when I have a full sd card inserted. The sd card is "verbatim sdhc 4gb" any idea? Thanks in advance
SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC (high capacity) cards. SDHC is not backwards compatible.
If your manual doesn't specifically mention SDHC cards or memory card size bigger than 2GB, then the camera almost certainly won't work with SDHC. My Lumix won't work with anything larger than 1GB SD.
Jan 18, 2011 | Panasonic LUMIX DMCZS7 DMCTZ10 Digital...
This camera reads "card error" and won't format a
yes. you can try to insert the sd card to a computer using any all-in-1 memory card reader. then if windows detects it, right click the card's drive in windows explorer then select format. choose FAT as file system type. before you put it back to your camera clean the card's contact points, insert the card and if the camera detects the card format it again using the camera's format tool.
Dec 19, 2010 | GE C1033 Digital Camera
Can't use 4GB SD card
does it work when you insert any other SD card?
Feb 14, 2010 | Kodak ZD710 Digital Camera
How do you put your sandisk microSDHC card with adapter in your camera
That depends on the camera. If the camera supports Sandisk Micro, then the SD card will fit into a slot. The slot is often located near to the battery.
You will just have to push card in and camera will automatically read card.
If camera does not read the card, ensure that the camera model can support SanDisk Micro, and that it will also support card size. Older cameras do not support big memory card (eg.4Gb)
Sep 05, 2009 | SanDisk 4GB microSDHC Memory Card
Sd card won't click into place on my Nikon d60
Check your SD card, there may be a piece of it missing. Did the same to my camera and looking into the card holder, there was a piece of SD card lying at th bottom! (I used a needle to dislodge it!)
Mar 11, 2009 | Nikon D60 Digital Camera
Nikon D40 Memory Card Error
Hello. Make sure the write-protect switch on the SD card is in the UP (nearer to the contacts) position. Try the card in an SDHC capable reader on your computer first. Note that the SD card can only be inserted one way - make sure you're not putting it in upside-down! If the computer recognizes the presence of inserted card (whether it can read it or not), format it at FAT32. When finished, remove properly (icon in system tray) and insert into your D40 slot, WITH THE CAMERA OFF!! Turn on the D40, and if it now recognizes the SD card, FORMAT it again, in the camera. Good luck.
May 26, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Cameras Logo
55 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Nikon Camera Expert? Answer questions, earn points and help others
