SOURCE: sim card transfer
on the A707 you can go to address book, right soft key is options, copy, copy to sim, multiple, click all, press ok. Thats the way the transfer from phone to sim.
if you are transfering from another phone to the a707, let me know, can tell you that too....
Clint Cartee
ATT Wireless
SOURCE: sony ericsson k800i blank screen need to transfer numbers from phone memory to sim card
Thats a cool phone, pity its screen is broken.... Here is my suggestion
Check the memory card or Sim on another phone...
SOURCE: memory card micro sd cannot format
i found something to fix it. or at least it worked for me
http://hddguru.com/download/software/HDDGURU-Low-Level-Format-Tool/LLFsetup.2.36.1181.exe
Install that, then run the program and CAREFULLY select your card from the formatting list
then do a low level format
Then format it on windows or phone or whatever
PLEASE BE CAREFULL NOT TO SELECT YOUR HARD DISK IN THE PROGRAM. IT WILL VAPORIZE ALL YOUR DADA
SOURCE: LG PHONE PICTURES INTO COMPUTER
If you bought the SD card from Verizon then you should have another card where you insert the card into the regular sized and it works that way. Good luck!!
SOURCE: Transfer "assigned media" to Micro SD
YOU CAN DO THIS BY MOVING YOUR FILES FROM YOUR MOBILE TO YOUR MEM CARD. THIS FUNCTION IS AVAILABLE IN YOUR MODEL.
IF YOU CANT DO SO. JUST TRANSFER THIS FILES TO YOUR COMPUTER VIA A DATA CABLE AND THEN TRANSFER THE SAME FILES FROM COMPUTER TO MEMCARD USING A MEMORY CARD READER.
HOPE THIS WILL HELPS U.
PLS. RATE MY SOLUTION.
NICE DAY
KETAN
