Hi, You can unlock your Nokia N900 safer and easier using unlock code. You can get the unlock code from www.onlinegsmunlock.com/nokia-n900/rs7wp9/ at affordable cost . Here are the steps for unlocking a Nokia N900, 1 - Switch on your Nokia N900 without any sim card.
2 - Don't bother as to what is displayed on your Nokia N900.
3 - Compose #pw+CODE+1#.
4 - The Nokia N900 would then display the message "SIM Restriction Off" and will be unlocked!
Fn + F1
Change Display Device.
Fn + F2
Wireless Control
Fn + F3
Battery information
Fn + F4
Decreases brightness on the integrated display only (not on an external
monitor).
Fn + F5
Increases brightness on the integrated display only (not on an external
monitor).
Fn + F6
Keyboard backlit(available only if a backlit keyboard is
installed)
Fn + F7
Mute
Fn + F8
Decrease audio Volume.
Fn + F9
Increase audio Volume.
Fn + F10
CD Previous - Play previous media file.
Fn + F11
CD Play/Pause - If there is Audio CD in system, Media player will play
music.
Fn + F12
CD Next - Play next media file.
Your "Num Lock" is on. Look for the num lock key (it's similar to the "caps lock" key in function) If the "num lock" is blue, you may have to hold a blue "fn" key when you press num lock
There's is probably a light at the top of the keyboard that'll tell you when num lock is on.
Your system comes with on-board diagnostics. Run the diagnostics to check if the problem is with the drive or windows.
To run the diagnostics follow the steps below
1. Shutdown the system
2. Press the Fn+Power button together
3. The screen will display color screens
4. Follow the prompts until it takes you to advanced diagnostics
5. Do a custom test on the optical drive.
If you are unable to run the diagnostics
1. Find the dell resource cd that came with the system
2. Insert the cd in and restart the computer
3. At the Dell logo screen press the f12 slowly 5 times
4. Select boot from cd/dvd drive
5. Press any key to boot from cd .... message appears press enter
6. If the system starts from the cd .. this would mean the drive is ok
First try to re sync. the key with the car.
To re sync the controller, please do as it follows:
1: close the vehicle from the driver's side with the key!
2: Wait until the alarm is armed.
3: With the unlock button pressed turn the key in the barrel to unlock position, then back. Now release the button.
4: Now with the lock button pressed turn the key to the locked position, and back. Release the button.
You need to press hold the FN key and press the F4 function key once which toggles the display to the External Display source like the television connected along with the LCD of the Notebook.
If the FN and F4 key combination is pressed again, the display will dissappear from the LCD of the Notebook and remain only on the external source.
If the FN and F4 key combination is pressed third time, the display will be back on the LCD of the Notebook and will not remain on the External display source.
Here are these details in other way :
First time pressing FN + F4 ---> Display on LCD and External display
Second time pressing FN + F4 ---> Display not on LCD but on the External Display
Third time pressing FN + F4 ---> Display back on the LCD and not available on External Display (Normal position).
Below are the details of what the Function keys in your DV1000 Notebook work :
fn + f1 Opens Help and Support Center
fn + f2 Opens print options window
fn + f3 Opens default Internet browser
fn + f4 Switches the image among displays
fn + f5 Initiates Standby
fn + f6 Initiates QuickLock
fn + f7 Decreases screen brightness
fn + f8 Increases screen brightness
fn + f9 Plays, pauses, or resumes an audio CD or DVD
fn + f10 Stops an audio CD or DVD
fn + f11 Plays the previous track or chapter on an audio CD or DVD
fn + f12 Plays the next track or chapter on an audio CD or DVD
fn + esc Displays system information.* (*To clear the system information display, press esc.)
Hope this helps...
