Question about Accutron Wrist Watches by Bulova Breckenridge Collection Mans Watch 26B29
How can I reset?
Replaced battery
Posted by A ciriello on
I have a Coleman digital watch. Four button. I replaced the battery and need to reset the time and date.
Click on your watch model number to open the instruction sheet below.
Your model number is located on the caseback of your watch
go here> http://www.gsi-usa.com/instructions/
Aug 16, 2014 | Coleman Mens Digital Dual Time Sport Watch...
Polar AXN300 Heart Rate Monitor Watch HRM AXN300 is not showing pulse
I would think it is the sensor circuit in the watch. When you replaced the battery did you activate the processor all reset for the watch? I do not know on your model where or how this would be activated.
Electronic watches normally have a reset procedure for when the battery is changed. Very important the watch's processor reset is performed after changing the battery. This is not any of the user readings reset. This is a reset for the watch's processor and system. It is sometimes a contact that has to be shorted out with the jeweler's screwdriver, or it is a contact that has to be shunted, or etc., depending on the model. Maybe if you call the support for the watch they will tell you this. Normally they do not like the user opening the watch.
Feb 10, 2018 | Polar AXN300 Heart Rate Monitor Watch HRM...
Replaced battery but unable to reset watch to correct time, etc??? says on sticker on back of battery, "short pads to reset" short what pads??
there is reset button beside the battery or you have another option is to push all the buttons of your watch to reset and you can now set the time, date and other that had to be set manually..
Jul 08, 2011 | Watches
Won't reset to zero (60 sec.) after battery was replaced
You need to "Reset" the watch's computer, this is done by removing the case cap, (Same as battery replacement) Look for a imbosed "RESET" and using a paperclip, Push gently in the reset hole for five seconds, Remove the paperclip, You should then have all funtions restored to "Factory Settings"
May 20, 2009 | Casio Watches
Timex rush new battery reset
good morning ! you need to use the pointed twisser to short the two reset pad ! thanks !god bless !...
Sep 02, 2008 | Timex Rush Sports Watch
Battery change and then reset
If you open already the watch,and you want to take the old battery,there is a clip that's lock the battery twist that lock.then the battery comes out and replaced with a new one. If you have already put the battery and no display you must reset it by shorting battery connection,in the plate there is arrow guide to the hole where you put your tweezers to short the connection.then the display appears 8888,that is already resetted take the tweezers..
click below for video guide;
G-ShockBattery Change Tutorial
hope this may help
DON'T FORGET TO RATE
Regards,
VOTIT
Jul 29, 2008 | Adidas Watches
Need to reset Ultrak 510 soccer watch
To set time and date:
Press and hold upper left button
Upper right resets seconds
Lower left changes item you wish to reset
Upper right moves number to next higher
cycle through using lower left
when finished push on upper left
In timer mode to reset timer:
use upper right to reset minutes
In alarm mode press and hold upper left
press upper left when finished
upper right toggles alarm on or off
Feb 12, 2008 | Watches
Accutron Wrist Watches by Bulova  Breckenridge Collection Mans Watch 26B29 Logo
79 people viewed this question
Top Accutron Watches Experts
Janelle Schoonover
Janelle Schoonover
Ngoro
Bill Boyd
Are you an Accutron Watch Expert? Answer questions, earn points and help others
