As long as I'm using the power sprayer it works fine when I stop spraying the engine stalls. Is there a pressure sensor or relief valve.
SOURCE: I have a Honda 3500 pressure washer. The motor
You need to start the unit and let it run for few minutes to get worm, make sure the water is fully open and the unit is fully cleaned. Push on the trigger on and off for few times not letting the unit shutdown, then start increasing the fuel mixture ¼ turn and push on the trigger again and see…this could be that the unit need service or the governor springs getting week if you got one on your unit…let me know how that work for you and please do not forget to rate my service so we can improve on it with your help. God bless
Testimonial: "The problem was the governor spring. Thanks"
SOURCE: Pressure washer with Honda GX160 5.5 HP OHV-Starts easily but...
what about the linkage between the governer and the carb. Is that working and not binding?
SOURCE: Pressure washer worked fine and suddenly no
If you remove the tip, will it work? If so, unloader valve is sticking and needs to be removed and lubed with lithium grease.
SOURCE: xr2600 excell pressure washer I was using it and
I have the same problem and it seems the piston in the back has a ring and the ring is broken i half i'm talking it to get fixed tomorrow i will keep you informed.
SOURCE: I have a honda excel 2500 psi , where would the
Many of the excel units don't come with a pressure relief valve but instead a thermal relief valve, it really depends on the model number of the pressure washer. You should only replace the thermal relief valve if it is leaking.
