Question about Wine Enthusiast 21-Bottle Dual Zone Touchscreen Wine Refrigerator
I am getting an error code EL when I turn the unit on - no cooling. If I turn the light on the fan go on and I have cooling but the fan and cooling won't stop and the error code changes to EH
Posted by Bill W on
David Parker
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 12 Answers
The temperature sensor is probably bad.
Posted on Jun 12, 2016
Hola buenas tardes tengo un problema con mi ford escape 2009 motor 3.0 que las ventiladoras de enfriamiento se me an quedado directac y no hacen sus ciclos de parar cuando el motor esta frio si no que...
Necesitas un sensor de enfriamiento del ventilador. Est? ubicado en el radiador.
You need a Fan Cooling Sensor. It is located in the radiator.
2005 Ford Escape radiator cooling fan repair. - YouTube
? 3:19
https://www.youtube.com/watch?v=3Sk5g4PGVWs
Sep 24, 2014 - Uploaded by hufhuffy
2005 Ford Escape cooling fan problems ,cooling temp sensor auxiliary fan control unit ,radiator fan switch ...
2009 Ford Escape Hybrid radiator cooling fan - YouTube
? 1:42
https://www.youtube.com/watch?v=tRdrV825xak
Mar 8, 2017 - Uploaded by stevenofpa
00243 2009 Ford Escape Hybrid radiator cooling fan - This video shows the engine cooling fan radiator fan ...
2008 Ford Escape Cooling Fans: Both Aux and Main Cooling Fans ...
https://www.2carpros.com/questions/2008-ford-escape-cooling-fans Jun 17, 2014 - I have replaced the Main cooling fan relay but didn't help. Not sure if there is ... 2002 Ford Escape Coolant Overflow Bottle Replacement.
2009 Ford Escape Cooling Sensors, Switches & Relays - CARiD.com
https://www.carid.com > ... > Ford > Escape Results 1 - 21 of 21 - Ford Escape Replacement Engine Cooling Parts - 2009 ... Ford Escape 2009, Coolant Temperature Sensor Connector by Standard®. 2009 ford escape replace cooling fan sensor Google Search
Oct 28, 2017 | 2003 Ford Escape
Friedrich ductless heat pump will not start up.
Did you check to see if the compressor is running? Check out start relay/capacitor.
Sep 21, 2017 | Heating & Cooling
Three rings are green one red on tv says error e73
Turn on unit until the red light flashes and the error code(E 73) shows up on the screen. Next insert toothpicks in the back of the console(while unit is running) into the cooling fans, this is to suppose to overheat the console and start two red lights flashing. Turn off console when this happens(unplug all cords from console) and turn the system back on.
Thank you
Jun 04, 2010 | Microsoft Xbox 360 Console
Flashing red light on the bottom right of the ring and an error code 73 picture on the screen
Hi,Turn on unit until the red light flashes and the error code(E 73) shows up on the screen. Next insert toothpicks in the back of the console(while unit is running) into the cooling fans, this is to suppose to overheat the console and start two red lights flashing. Turn off console when this happens(unplug all cords from console) and turn the system back on.
This solution will fix your problem for sure. Thank you!
May 12, 2010 | Microsoft Xbox 360 Console
When i turn on my xbox 360 it turns to a black screen and says i have error E73 and when i went to Xbox.com it didnt say anything about it
Apr 14, 2010 | Microsoft Xbox 360 Console
Xbox 360 E73 error. What do I do?
Apr 07, 2010 | Microsoft Xbox 360 Console
Fan motor does not blow hot or cold air when turned on
your fan motor is located on firewall behind engine towards middle of car under a cover gain acess turn fan on inside car lightly tap back of motor if fan starts running you have a bad fan motor i assume you have already checked your fuses
Mar 16, 2010 | 1999 Cadillac Eldorado
CLC 1180 gives the error code E804 000B and instructs me to turn the unit off and on again. Once this step is completed, it reoccurs.
E804 0006 The laser scanner motor
cooling fan (FM4) has
stopped to rotate in error.
There is no 000B in the manual....so I assumed it was a six.
The sub codes possible are 0001, 0002, 0003, 0004, 0005, 0006, 0007 and 0008. They all pertain to cooling fan failures.
Oct 19, 2009 | Canon CLC 1150 Color Copier
Error code of 6 flashing light on circuit board,
There appears to be a short in the unit. Not sure where. The power to the fan is not interrupted completly when the fan shuts down, still feeding voltage to the fan, keeping it running slow. Before checking the wiring, please turn off power first.
Nov 19, 2008 | Heating & Cooling
Thank you. there are some other signs i don't know about.
The black triangle means AUTO, means the fan speed adjust by itself from high-mid-low speed depending in room temperature but the unit is cooling for this function the same COOL mode. Plasma is in the remote control but it never mention in the manual.
If the unit dont cool check your temperature setting and mode setting it should be in cool mode and temperature setting should be 18C. But if still don't cool check some error code like blinking light at the indoor panel check how many blink appears to get the correct error code.. If the light is blinking 3 times it means that the room air or coil sensor is defective.
abc4048.jpg.
Apr 28, 2008 | LG LSC121PMA Split System Air Conditioner
Wine Enthusiast 21-Bottle Dual Zone Touchscreen Wine Refrigerator Logo
1,996 people viewed this question
Top Wine Enthusiast Furniture Experts
John Tripp
John Tripp
Tom Chichester
Are you a Wine Enthusiast Furniture Expert? Answer questions, earn points and help others
