You will not be able to tune in TV stations unless you first have a TV antenna installed. Once connected to a working antenna the set should find stations easily enough ?
But you do not need to tune anything in to use it with your skybox -simply connect the skybox to the TV using an HDMI cable (available anywhere that TV's are sold) noting the number of the HDMI socket that you plug in into on the TV. Then, using the TV's remote, set the TV to input signal from that input (HDMI 1 for example) and you should be fine?
