Question about Moen & One Handle Tub & Shower Faucet
Brand new shower installed. will not stop running water. wont shut off water with tap. What's wrong?
Posted by therese on
I can't get shower head pressure from the outer head of my new grohe freehander.
Everything you installed new. Please chack if not one of the gaskets came in a pipe or a line. I once had a rubber ring almost complete blocking the water flow.
Nov 01, 2014 | Grohe Shower Freehander 27 007 Chrome...
No hot water coming out of shower faucet but fine every where else
If it is a pressure balance set of taps then your hot water limit stop is not set high enough. What brand of tap is it?
Apr 18, 2013 | Home
When shower is in use pipes vibrate and water starts to pulse,when faucet on sink is turned on it stops .What's up?Shower is an Aquasource brand.
You need to install water hammer arrestors in your basement it prevents this, if you have them already there water logged. All u do is shut off your water to your house and drain it down to the lowest point....when its done draining u fill it back up again slowly. Your water hammer arrestors may have become water logged when the new shower was installed
Nov 14, 2012 | Plumbing
My triton shower won't turn off and has no hot water
Your supply pressure is too high for the unit, it is too much for the solenoid to shut off, you need to put a pressure limiting valve inline.
Mar 10, 2012 | Home
We just installed a moen shower faucet. Water pressure is almost nil. It's a brand new house so debris and other things should not be a factor. When the faucet is removed the water pressure is back...
There's a clog in the shut off, line to faucet, or in the faucet cartridge ... hook it up to a supply tube on another faucet, it connect to a garden hose to check if faucet is problem.
Water pressure problems on following link:
http://waterheatertimer.org/Low-water-pressure.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 08, 2017 | Moen 3175 Legend One Handle Shower Faucet...
We just bought and installed a brand new Glacier Bay Tub and shower set... #814 278. We turn it on and no hot water comes out. Help!
Try to open the left hand taps head and see if maby the seal rubber isent stuck that whem u open the tap iet stays in the close posision
Jul 19, 2010 | Home
Hi i just installed a triton cara shower and the water wont turn off
It is probably the water solenoid valve wich is stuck or bunt out.
If it is brand new, maybe you have warranty.
May 20, 2010 | Home
Pressure is high can it be adjusted?
Is this a new install? Is this happening with cold and hot water, or just one? Is it just happening with the shower valve open if it's not a new install. it may be the shower valve bad. These can be replaced easily, Lowes $7-14 depending on brand. The water has to be shut off from coming in to the shower. If it is happening with the water running on either hot/cold, the each one has a valve like the shower knob. These go bad and are replaced the same. These release to much water when the rubber seal breaks down inside the valve. Let us know which way it's happening and maybe able to help more.
Jan 02, 2010 | Delta & Single Handle Shower Faucet
Moen Tub Faucet.. Water won't stop running.
change the washers first if that don't work change the inserts buy all at same time and return if not needed . Thank you for useing fixya please rate me
Feb 25, 2009 | Moen 2919 Chateau Two Handle Tub and...
New shower installed doesnot always kick pump in
some times if there not enough water flow passing through the pump it wont kick in make shure all other taps ar off an try that ,have you got a good water pressure in you house?
Jan 26, 2009 | Home
Moen & One Handle Tub & Shower Faucet  Logo
280 people viewed this question
Top Moen Home Experts
Mike
john h
Bruce Robin
Are you a Moen Home Expert? Answer questions, earn points and help others
