Question about Moen & One Handle Tub & Shower Faucet
The water wont shut off. the shower is always running with water
Posted by therese on
My water heater heats everything except my lower shower
Let's walk our way thru this one: I assume you have an upstairs shower, and a downstairs shower?-- Are you able to follow the pipes coming out of the Hot Water Heater?-- Can you trace where the pipes to the upstairs shower go?-- And what about the pipes to the lower shower? -- Do they BOTH come off the HOT water pipes coming out of the top of the HW Heater?
A big help in tracing pipes, is by having the hot water run in the Shower that is getting HOT water-- Feel the HOT! pipe?-- Now-- shut that water off, and go to the lower shower-- When it is running, can you hear water flowing out of the pipes at the top of the Hot Water Tanks?-- or do you feel Cold water moving-- Can you travels where it is flowing from? Get back with me, and tell me what you are feeling, and hearing-- Mack B
Oct 15, 2013 | A.O. Smith Ao Smith Bt-80 Conservationist...
How to get rid of water pipes noise at home
one of your fixtures could have a loose rubber gasket inside the shut off. run your faucets toilets and shower and see which one makes the noise. or you can always call a local plumber
Apr 04, 2013 | Plumbing
Hi there, I have a bosch aquastar 125b waterless tank. My problem is that i am not getting hot water at all. The water runs during the shower and it stays warm. HELP!!
This should run two showers at once with no problem. If you have a shut off valve on the cold side of the heater, try closing about halfway. This will slow the water flow and the water will have more time to heat up as it pases through the tank. If you dont have a shut off valve, just cut back the hot water valve on your shower and do not use any cold water. If it gets too hot then turn on a little cold water. The object is to slow the speed of the water going through the tank. Tankless heater take a little getting use to but they work great when you know how to treat them. On my shower I turn the hot all the way on until it gets hot and then add a little cold water to bring the temp down. You may have too much water going through too fast to be able to heat it up to what you need. Try this and see how it works.
Mar 26, 2011 | Bosch AquaStar 2400ES-NG
Always running out of hot water after one shower
Sorry to read about your problem, I hope this helps you out.
Get a rinnai tankless, and never have the problem again..
O you can have a couple of problems..your temp got set low..go check it... tank is old or temp probe is defective...
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Went to change the handle in my shower when putting it back together it wont shut off water runs even while turned off.
try taking handle off and shut off water from stem..nall inside body may have turned>>once off install handle at point where it goes in
Nov 22, 2010 | Delta Plumbing
Water comes from both the shower head and bath tub faucet when bath is turnd on and wont turn off when shower is on
if it is standard shower where you pull the knob up when water is running. the pull knob lifts a flap to shut off water to bottom faucet it proably has some buildup on the flap clean well with some clr or other calcium cleaner like it so the flap gets a clean seal on downspout
May 08, 2010 | Home
Need to clean single knob shower cartridge from what i read - where do i shut off water first? hot water running to bathroom - sink gets it - in shower, cold water good, hot water trickles - read lots of...
To clean it, shut off the discharge valve at the water
heater. Then, you shut the valve off of the main water supply. After which, you can start cleaning the single
knob shower cartridge. After the cleaning job, you can
open the discharge valve of the water heater, then, the
valve of the main water supply.
Nov 11, 2009 | Moen & One Handle Tub & Shower Faucet
New shower installed doesnot always kick pump in
some times if there not enough water flow passing through the pump it wont kick in make shure all other taps ar off an try that ,have you got a good water pressure in you house?
Jan 26, 2009 | Home
Moen & One Handle Tub & Shower Faucet  Logo
275 people viewed this question
Top Moen Home Experts
Mike
john h
Bruce Robin
Are you a Moen Home Expert? Answer questions, earn points and help others
