I have a 3 year old TC-P60UT50 PANASONIC PLASMA. When I turn it on it shuts off and the power light blinks 6 times. Looking online it looks like it might be the "SC board". Can you recommend what i need to fix my TV? Also, is it worth fixing this model of TV? I have only had it for 3 years and am a little disappointed that it has not lasted.
SOURCE: Panasonic TC-32lx60
I work for another site that sells service manuals and provides free tech support, and there is nothing in the manual about error codes. The power supplies would need to be troubleshooted. The manual is anew one but if you would like a copy send them an email and they will upload it to the website for you to purchase, they email all manuals that one was scheduled to be loaded to the site this weekend but they will upload it earky if youd like it. Heres the link.
http://servicemanuals.vstore.ca/
SOURCE: Panasonic Plasma TV problem
the cost depend upon the itmes (dameged ic, on the mother board of your t.v,)which can only bw assessed after opeing it,,,
service charge will be approx. 300 buks,
and approximately the ic's will cost, about 1200 bucks
SOURCE: PANASONIC PLASMA TC-P50C2 The tv
Hello
Your TV is in warranty period I thinks. If so, company is liable and will repair it free fo charge. There is "repair,replace, refund gurantees. Your gurantee card and broshure will tell you that. Look at it.
For what you are going to take the risk.
SOURCE: I have a Panasonic Model TC-P50S1 plasma TV and
Panasonic utilizes the blinking light as a form of self-diagnostics, similar to the "check engine" light in your car. If you've ever experienced that, you know that a check engine light could indicate anything from a loose gas cap to a major failure.
Panasonic uses the number of times the light blinks, to aid the technician in trouble-shooting the problem. The blinking light indicates an area of concern and helps the technician to isolate the problem and order the correct parts. This in turn speeds up the repair process, keeps parts cost down, and helps both you and the servicer by allowing the technician to complete a repair in one trip in most cases.
So contact an authorized service center.
SOURCE: Panasonic Viera 65 inch tv shut off, will not turn back on. Red light blinks 7 times.
Power supply or related to it.
