Question about Alcatel Mobile Phones Composite Device Driver
Which type process is used for blocking SIM? - Alcatel Mobile Phones Composite Device Driver
Posted by arunbalachandran on
L Pfaff
    Top Expert:
  • Alcatel Master
  • 11,573 Answers
Puk is block can only dial SOS nr. please help
PUK is Personal Unlocking Code is used in GSM mobile phones to unblock the blocked phone. If you type in the wrong PUK ten times in a row, the device will become permanently blocked and unrecoverable. So it means you need to buy a new SIM card or if you are using a post paid SIM you can call your network provider for them to change your SIM card.
I hope I answered your question.
Thanks a lot!!!
Aug 16, 2011 | Computers & Internet
I cannot login
If you cant login to your SIM card and it has a password:
If your SIM card is blocked from to many tymes of typing the wrong password you will have to go to your phone operator and tell them that you blocked your SIM card
If your SIM card isnt blocked : Step 1 . Turn off your phone Step 2 . Get out your SIM card out the phone Step 3 . Blow air in to the place that your SIM card should be (you can use your mouth or can of compressed air) Step 4 . Blow your SIM card with air (you can use your mouth or can of compressed air) Step 5 . Insert the SIM card back in to place
!!! If this fails you will have to visit a cetificed phone service !!!
If you made your SIM card in to Mini format theres a chance you damaged your SIM card
Jul 28, 2011 | Cell Phones
My E63 has been blocked by the Optus network...how do i un block it
Your handset can become fully locked due to exceeding the number of attempts to enter the correct unlock code. The type of handset you have will determine what process to follow to see if the handset can be unlocked.If your handset appears with a Code Error or does not unlock with the first or second attempt, you will need to call Customer Service to confirm the code. Once the handset is fully locked it will require manually unlocking from Optus and your handset will need to be sent away.
1 Insert SIM
N.B. Can be unlocked with SIM removed from handset however there is a 5 second time limit 2 Power phone on 3 Type: #pw+15 digit code+1 (where '15 digit code' is the unlock code) 4 Press Hash (#) - SIM Restriction OFF will display on screen for one second
Troubleshooting:
  • If the unlock code is incorrect the phone will display the message 'Code Error'
  • If the user tries to unlock a phone which does not have SIM Lock activated the phone will display the message 'SIM was not restricted'
  • If the syntax (#pw+) is incorrect when entering the unlock code - nothing will happen.
Jun 07, 2011 | Nokia E63 Cell Phone
My sim card was blocked.................in aircel sim...........how can i solve this problem
This problem occur when you enter the incorrect pin three times, now the sim card is blocked. check the manual that came with the sim card or your sim certificate and you will see a number called PUK( personal unblocking Kode) input the number when the phone ask for enter puk code, press ok, and enter your new pin two times, the sim card will be unlocked. but in the process where the phone is not asking for puk code, you will have to put your sim into another phone preferable nokia phones.
Thanks and good luck
Feb 16, 2011 | Computers & Internet
How can i use sim in dell studio 1558 ? What are the advantages of sim slot ? What are the processes of using sim ? What type of sim can be used ?
The SIM slot takes photographs from digital cameras. There will be a menu when one is inserted and with the projector displays and presentations can be produced.
Dec 29, 2010 | Office Equipment & Supplies
What should my puk pin be???
problem can be solved.When you bought the Sim card of the line you are using did it come with a Pin request?,
if yes, that means the Pin has been blocked due to typing the Pin code wrongly.
So your Sim card has been blocked for a why and i that process you are unable to make or receive calls.
To reactivate the Sim card, you need to contact the service provider (customer care line) for the Sim card you are using to Help you activate the Sim.
And good thing is that it is free, so you can call them and activate the Sim card and keep enjoying your calls.
Have a nice day.
Mar 19, 2010 | O2 Samsung SGH-E250 Cellular Phone
My Nokia 1208 phon asking PUK coad whos i dos'nt knok My Sim is Idea & Sim No. 89918 92100 01551 25550 6
hi bro
solution related this prob is jus keep ur mobile phone now as it is and dont enter any key cuz it wont help ur and after some chances your sim cardc will b blocked and then ull hv to pay for new sim card
i hv to solutins regarding this----------
process (1) just take anothet mobile phone and call the customer care of the sim which ius asking for the PUK code
(remember u can do this with any number but it will charge for meking call but if u hav the number ofd the same company of blocked sim then it will cost u nothing) tell the customer care operator tht you want the PUK code for ur blocked sim they will ask the mobile number and sim number which is printed on ur sim card of tht blocked sim . and they'll tell u the code
just insert the sim in ur mobile n switch it on and enter the code after tht mobile ask for new PIN code just make it n also remember it for future.
process (2) just go to ur mobile operating service center of the sim card
and rest is on them.
hv fun
and dont forget to give me higher ratings
Mar 14, 2010 | Nokia 1208 Cellular Phone
I enter in my sim pin to change it but it won't let me change the
Switch your phone off,and switch on,
Then wait for about 5-10 minutes, and retype your pin again.
If not working,Go back to your sim pack where you cut out your sim from and check for puk number.
Type in type in the puk number,then it will ask you to type in new pin, and after it will ask you to type your new pin again then,you can start using your sim again.take care.
Jan 21, 2010 | Motorola Mobility RAZR V3
Accidently blocked my SIM and don't know how to unblock it and lost the box that came with my phone. Please help.
can you explain more detail about your problem.
what is blocked sim that you mean and what cellphone brand and type that you use?
Dec 31, 2009 | Samsung Epix Cell Phone
Forgot my code...
Your SIM Card is most likely blocked. When u type an incorrect pin 3 times, your pin is blocked. You then have 3 chances to type your SIM card's Pin unblocking code (PUK). If you type an incorrect PUK, your SIM card will be blocked and you will need to call your service provider.
Aug 24, 2009 | Apple iPhone Smartphone
Computers & Internet Logo
189 people viewed this question
Top Alcatel Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Marvin
Marvin
Are you an Alcatel Computer and Internet Expert? Answer questions, earn points and help others
