Question about NEC Display NP-V260X Dlp Projector - 3D Ready 1080i HDTV 4:3 F/2.41 2.55 NTSC, Pal, Secam 1024 x 768 XGA 2000:1 2600 lm HDMI VGA Ether278 W 2 Year Warranty
NEC V260XG temperature error
My NEC V260XG Projector will turn on correctly for around 10 mins. Everything works fine but then turns it self off with a temperature error. This is very annoying during films!
Posted by Sam Jollow on
  • Sam Jollow
    Sam Jollow Apr 23, 2016
    There is no air filter on this model
Jim Peters
    New Friend:
  • 8 Answers
The most common cause is dust inside the projector that leads to overheating & auto shutdown. If you have an air compressor you can use the blow tip accessory to blow as much dust out as you can without taking apart the projector. You may get by using a can of compressed air available at Walmart, etc. electronics section. Concentrate on vented areas & where you can see or hear any fans. Do this outside so it doesn't make a mess. If you know how to take out the lamp there's usually close access to the main cooling fan through the lamp compartment, blow air through there & it will follow the right path to exit correctly without blowing dust all over the inside.
Posted on May 03, 2016
TheSbuhrman
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 38 Answers
Clean the air filter
Posted on Apr 13, 2016
Testimonial: "There is no air filter on this model it was one of NECs non filter products"
Nec v260xg image alignment problem
Try the Keystone correction function to correct the trapezoid distortion.
NEC VT470 Multimedia projector
Try to reset the projector. Turn the power off. remove the power supply cable from the main socket. Leave it for 30 min. Turn on again. Before turn on(Make sure) 1.0 power cable install correctly 2.0 Lamp cover install correctly. 3.0 No excessive heat around the projector All this can be refer to the user manual.
NEC V260XG temperature error. How to Stop??
check the thermostat; it appears that either the thermostat is not working properly, or is not set right or damaged
7helpful
3answers
Status light is blinking red, power button orange nec vt700
Hello
Look at the number of blinks of the status light.
[1] If it blinks at one cycle (0.5seconds On and 2.5seconds OFF) : Lamp cover error or lamp housing error. Replace the lamp cover or lamp housing correctly.
[2] If it blinks 2 cycles (0.5 seconds ON and 0.5 seconds OFF): Temperature error. The projector is overheated. Move the projector to a cooler position.
[3] if it blinks at 4 cycles (0.5 seconds ON and 0.5 seconds OFF): Fan error. Fans sill not work correctly.
[4] If it bliks at 6 cycles (0.5 seconds ON and 0.5 seconds OFF): Lamp fails to light. Wait a full minute and then turn on again.
[5] If it blinks continous (Red): Lamp has reached the end of its life. Lamp replacement messege will be displayed. Replace Lamp with same type and number. After replacement reset lamp hour. OK.
3helpful
My NEC vt 595 was working fine last night and today i went to turn it on the status and power light started flashing red and orange and there is no picture
if Power is flashing orange - then it's cooling down
if Status is flashing red - then there are 4 flash combinations.
1 cycle (0.5sec On, 2.5sec Off) lamp cover or housing error
2 cycle (0.5sec On, 0.5sec Off) temperature error
4 cycle (0.5sec On, 0.5sec Off) fan(s) error
6 cycle (0.5sec On, 0.5sec Off) lamp error
Which is your condition?
1helpful
My projector turned off in the middle of watching a movie. One of the indicator LEDs which gives coded blinking for different problems with the projector says there is a problem with the lamp temperature....
hi,
check the fan one more time . may be its speed is low. if it not rotate at the correct rpm, the lamp will get over heated. check the fan if available replace it and try again.
ok
1helpful
NEC MultiSync VT540 not turning on - Temperature error
Hi
if the status light is blinking red in 4 sec interval it means that there is something wrong with cooling system. you shold check if there is a thermostat failure or if there are any switches that are not turned on. i suggest you to open the device (using screwdriver) and check if there are any switches broken or damaged.
i had pretty much the same problem (one second interval). i took off the cover and there was a broken switch and i just short-circuit it and now it works
Sorry for my english
2answers
NEC Multisync MT1000 Projector - Green Hue
its not the bulb problem . the lcd block need sto be replaced , better to buy new projector
3helpful
3answers
NEC LT30 - Lamp dosen't turn on.
From the manual: To reset the lamp hold down the "HELP" button on the remote for 10 sec and the lamp indicator will turn off. Then start up the projector again.
It worked for me!
NEC Display NP-V260X Dlp Projector - 3D Ready 1080i HDTV 4:3 F/2.41 2.55 NTSC, Pal, Secam 1024 x 768 XGA 2000:1 2600 lm HDMI VGA Ether278 W 2 Year Warranty Logo
Top NEC Audio Players & Recorders Experts
Ekse
 Grubhead
Grubhead
Are you a NEC Audio Player and Recorder Expert? Answer questions, earn points and help others
