If your Hisense 55-inch 4K TV with Android is turning off randomly, and you have found that the power supply board is wet, it is likely that the issue is caused by a problem with the power supply. Replacing the power supply board may resolve the problem, but it's important to consider the following before making a decision: Safety: If the power supply board is wet, there is a risk of electrical shock, so it is important to make sure that the TV is unplugged and that you take appropriate safety precautions before handling the power supply board.Root cause: The problem could be due to a leak or another issue that caused water damage to the power supply board. If the root cause of the water damage is not addressed, the new power supply board may also be damaged.Difficulty: Replacing the power supply board can be a difficult task, and it requires some technical knowledge and the right tools. It's important to make sure that you are comfortable with the task and that you have the necessary tools before attempting to replace the power supply board.Cost: replacing the power supply board may not be a cheap solution, and it may be more cost-effective to consider a new TV.It's important to have a professional technician to check the TV and confirm if the power supply board is the issue and if it needs to be replaced. If you're not comfortable with the task of replacing the power supply board, it's best to contact Hisense support for further assistance or have a professional technician to check the TV.
1. Why hisense TV red flashing power light has sound but no picture
There could be a few reasons why your Hisense TV has a red flashing power light but no picture. It could be an issue with the TV itself, the power supply, or the input signal. Let's take a look at each of these possibilities in turn.
2. How to fix hisense TV red flashing power light has sound but no picture
If your Hisense TV has a red flashing power light but no picture, there are a few things you can try to fix the problem. First, check to make sure that the power supply is plugged in and that the TV is receiving power.
Next, check the input signal to make sure that it is compatible with the TV. Finally, if the TV itself appears to be the problem, you can try resetting it.
3. What to do if hisense TV red flashing power light has sound but no picture
If it was an open "internal fuse" the error code wouldn't show!!!... bad advice...
I looked in my Hisense service manuals and 3 blinks error code is LED rail shutdown from over voltage or over current, most likely you have some bad lamps in the panel, you can open the panel up and take a 3 volt power source, like 2 AA batteries and test them one at a time, replace the ones that are bad or its easier to replace the entire strip..Good luck
Power supply regulator board fault. Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box. http://electronicshelponline.blogspot.com/
It will be best to replace the power supply regulator board as card basis.
Check voltages in power supply to determine if power supply is bad. Check vs, va, vsc, vce, 5v, 12v, 3.3v, 1.8 v to see if you have these voltages coming out of the power supply.
Is the standby LED light off ? Do you hear clicking sounds when you press the power button on the TV ? If not it's probably the power supply board. Look at the fuses(s) on the power supply board. If the fuses are good you may have to replace the board if bad.
