Question about Chevrolet 2004 Chevrolet Aveo LS
How can I get a wiring diagram for 2004 chevy aveo indicators
Indicator light is flickering very fast and we need to find a way to fix the problem
Posted by alma oelsen on
5 Related Answers
Anonymous
  • 109 Answers
SOURCE: 2004 Chevy Tahoe stereo wiring diagram
BLACK-ground
RED-accessorie
YELLOW-power 12v
PURPLE-left rear
GREEN-right rear
WHITE-left front
GREY-right front
BLUE-REMOTE
and the other blue one is for remote antenna..
Posted on Dec 04, 2008
Anonymous
  • 295 Answers
SOURCE: Headlight wiring diagram for 2004 Chevy Impala
I would go to Alldata.com on line for your vehckle to get the wiring diagrams.
Posted on Jul 18, 2009
Anonymous
  • 74 Answers
SOURCE: clock, and dome light (2004 aveo)
If the fuse blows when you start the car their is a bare wire somewhere in the wiring system that is grounding out when power goes through the system. Thier is a possibility of it being something else that is on the same fuse. You will have to trace the wires to find out what and where it is exposed. Your switches should be tested also. The switch that turns the light on manually and the one located in the door jam itself that turns the light on when opening the door. You should bring your car to a mechanic who is qualified in electrical dianosis. I hope this helped you out. good luck..... It would be appreciatted if you could rate my answer. tThanks....MIKE-
Posted on Aug 25, 2009
tntjasmine
tntjasmine
  • 24 Answers
SOURCE: Rear speakers for Chevy Aveo
you can access them from under the package tray inside your trunk compartment
Posted on Aug 26, 2009
Ismael
  • 170 Answers
SOURCE: serpentine belt diagram for 2004
Follow this link, page #123, Diagram #5-57. Good Luck.
http://www.daycoproducts.com/daycoweb.nsf/cf652a4feb630ad0862571a4005ae40c/1120b6e8f406fd3e862574c000569a91/$FILE/SerpentineBeltRoutingGuide.pdf
Posted on Sep 28, 2010
Is there a fix for my lights flickering on my 07 dodge 3500 6.7 I have try just about every thing I can with out taking it in to be looked at
Flickering is an indication of a loose connection. Check the wires to the lights. While in park and the lights on, wiggle the wires and connections to see if the lights flicker. Also check that the bulbs are installed securely.
Feb 10, 2016 | Dodge Cars & Trucks
LED TV pulsing
How many have 'blinking' issue with Samsung led tv - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJan 26, 2011 - I am trying to get the number of people affected by this nagging blinkingissue with the latest Samsung led tv's. If possible it would be useful to ... Samsung LCD TV Screen flickering (LN55C630K1F)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung LED with flashing standby light on front
Apr 17, 2014
More results from www.cnet.com
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical ...
Jan 18, 2016 | LG Televison & Video
Why will the left hand side flickers (front, back and side)not be working on my Polo Comfortline 1.4 2012. I have checked relevant fuses and all fuses are fine
The reason it flases fast is to tell you the bulb is out or as in your case not getting current. a connector is loose or corroision has set in some where. Turn on the emergency flashers do all sides work then? Remove each bulb an use an ohm meter to test if there is something wrong. While doing that use the multimeter or voltage tester to test if a voltage is going to the lights. I love VW's great cars. I am not sure if the signal lights are controlled by computer or not. But even so the relay is working fast which tells you the signal is trying to get there. If you can get a service manual or wiring diagram you can trace the wires back to somewhere. We once found the dome light inside had a wire just scraping the top an shorting out the lights an cigarette lighter. Try to chase the wiring yourself before paying for service to do it. I would bet it is a loose connector or frayed wire somewhere near the fuse panel or in the line kinked up.
Jan 29, 2015 | Cars & Trucks
What resistors do I need to fit LED tail lights to a 2012 PX Ford ranger ute
fast blinking light tells you that one of the bulbs is bad. replace the bad one and it should be fixed not need for resisters EVER
Jan 05, 2015 | Ford Cars & Trucks
Left indicator light flicker too fast
If the right side works properly, switch all indicator bulbs one at a time. test with each bulb change. Untill you find the one that makes it flash at the rite timing. I had a bad rear bulb. The brake filiment was laying on the tail light filiment. This made the blinker timing bad.
Jan 26, 2014 | Hyundai Tucson Cars & Trucks
Gear shift indicator lights flicker on instrument cluster
Sometimes on the shifter its self they use two different items, some use a medal rod and some use a cable like an ebrake. if its a cable one it may have stretched and isn't going back to its actual spot for the instrument lights to work properly. you can tighten that cable.that's all I can think of right now good luck.
Dec 07, 2013 | 2002 Pontiac Grand Prix
I have a renault megane 2.0 convertible, my lefthand indicator stays on when stalk is in lefthand position and also in mid position, it only cancels in righthand position which means I have no righthand...
Hi, my lefthand indicator light is not functioning propely on my Renault megane scenic 1.6. 2001 model. there is that flicker sound when I turn it on and it ticks very fast and nothing flashes on the dash and nothing on the external lights as well. It also does the same thing on the hazards but the right hand side works perfect. please help. EDDIE
Jul 10, 2013 | Cars & Trucks
My nokia BH-102 bluetooth headphone could not connect,can it be fix?
YOU TRY TO CONNECT YOUR BLUETOOTH IN FOLLOWING WAY
JUST OF BH-102 AND ON IT AGAIN WITH CONTINEU PRESSING POWER OR ON BUTTON U SEE INDICATION LIGHT GETTING FAST BLINCKING WHEN THIS INDICATION LIGHT FAST BLINKING YOU SEARCH FOR BH-102 THIS FAST BLINKING ONLY FOR SOME TIME
May 20, 2012 | Nokia Lands Phones
The light on my chest freezer will flicker on and off when I open the door. It will only remain on when the door is in a certain position. How do I fix this? Secondly, the red "on" light on...
Both light flickering probably indicates a problem with the plug or the cord. If it was just the inside light I would suspect the door switch, but both light would indicates an open short in the wires or plug.
Check the plug connection at the wall and see if it is loose. While unplugged check the cord for any nicks or cuts. Plug something else into the same wall receptacle , like a light and see if the power to the receptacle is ok.
If none of the above work then it is time for a qualified repair person.
J
Feb 20, 2018 | Woods Chest Freezer C1501W3
The light that is supposed to indicate on/off is flickering. However the freezer still works fine. How can I fix this?
The flickering light is nothing to worry about... as long as it is flickering it is considered to be "on"
If there is no light then you need to worry...
The light flickering is not something that you need to fix...
heatman101
Jan 12, 2011 | Frigidaire 7.20 cu. ft. / 204 liter Chest...
Chevrolet 2004 Chevrolet Aveo LS Logo
318 people viewed this question
Top Chevrolet Audio Players & Recorders Experts
Marvin
Marvin
Glenn Smart
Glenn Smart
Vernon Taylor
Are you a Chevrolet Audio Player and Recorder Expert? Answer questions, earn points and help others
