Question about magicJack Plus
My phone number is 647-932-9081
How do i can i solve my problem my phone number is 647-932-9081 thank you
Terry Hair
  • 4,134 Answers
Just some advice for the future. You ask how to solve your problem, but you aren't saying what the problem is. Thus we cannot assist you. To make matters worse, you give out your phone number to the entire world over the Internet. That is not a smart thing to do. Now you have two problems - the one we don't know about, and the fact that you are going to be getting calls from all over the world now. Think before you type......
Posted on Apr 12, 2016
I cannot call any number. it says active incoming call diverts
Carefully apply this recommendation to solve the call divert problem.
##002# then send and also ##21#
Note:the command should be apply one after the other then you will see the respond on the screen that the problem is solve.
Please rate this four thumb if it solve your phone problem.
Good luck and thanks for using fixya
Dec 25, 2010 | Nokia 6111 Cellular Phone
Nokia 2700c barring password code
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
if not solved tell me your IMIE number
type *#06# on your phone to get IMIE number
If not solve format your mobile by these steps
1. Switch off your Nokia phone
2. Now Press following key sequence *#7370# or *#7780#
3. Enter Default lock code is 12345.
4. While holding these buttons, press the power button and switch on the phone.
5. Wait for message ‘Format
thanks
Aug 16, 2010 | Nokia Classic 2700 Cell Phone
Please help. Nokia 1600 I saved my info from phone to Sim... now.
yap..just removed the duplicated numbers and your problem is solved..dont forget to vote..thanks
May 28, 2010 | Nokia N95 Cellular Phone
I have this problem, which unfortunately I don't know how to fix. All the calls that come to my mobile are immediately redirected to message center. The phone doesn't even ring.
You must have changed the call divert settings on your phone to your message center number and this is automatically diverting all your calls to your center number.
You need to go to your settings and cancel all call diverts to solve this problem.
You can also solve this problem by master reseting your phone.
Thank you for using Fixya,
Kenneth.
Mar 21, 2010 | Nokia Cell Phones
I wont copy contact from phone to sim
Hey welcome to fixya. I hope u 'll be fine
If u have not changed pin number before then enter 12345 if it demands pin no before copying the contacts.
i hope problem 'll be solved
If u like this solution, Please do rate me.
THANKS
Feb 25, 2010 | Nokia 2310 Cellular Phone
Hi, i have a Nokia 6500 and it is asking for a restriction code. i want to know what the IMEI number is for this phone. How do i find it?
Hello
To find your IMEI number, press *#06# on your keypad a number will appear immediately on your screen,that is your IMEI number
Problem solved!!
Thank you for visiting Fixya
Feb 22, 2010 | Nokia 6300 Cellular Phone
Do you havew to delete existing phone numbers in Clairity W-1000
Yes I did solve my problem. Just lift the receiver, Push program key, enter full number and push program key again, then push the button above the space you want to store the new number in and hang up the phone. Did not have to delete the old number. Thanks.
May 12, 2009 | Clarity Walker 1000 Hearing Impaired/High...
Forgot security code
Obtain your IMEI number by dialing *#06# on your mobile. You will see a number on your set, which is called the IMEI number of that set. Pass that number to me. I will give you the security master code.
Cheers. Thank You.
Jan 09, 2009 | Nokia 6288 Cellular Phone
Cannot unlock my LG VX4650
Try the last four numbers of your cell phone number.
Jun 02, 2008 | LG VX4650 Cellular Phone
Car kit
The model/serial number/IMEI number, should be written under the battery.
If you switch off the Bluetooth car kit, when you take the handset with you, it might solve your problem.
Feb 20, 2008 | Cell Phones
magicJack Plus Logo
46 people viewed this question
Top magicJack Office Equipment & Supplies Experts
ray gallant
C. David Graves
Are you a magicJack Office Equipment and Supply Expert? Answer questions, earn points and help others
