HI,
Need more information on the unit to help you, not all refrigerators are the same. Check your light switches and see if one is sticking closed cause the light issue. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
SOURCE: whirlpool GD5RHAXNQ SIDE BY SIDE, CHIRPING NOISE WHEN LIGHT IS PLUGGED IN
short in the control panel. or the ground in the control panel is loose.
SOURCE: Ice & water control buttons
sound like a bad(shorted) dispenser user interface INTERFACE DISP ASM WR55X10415
SOURCE: Temperature Control not working on LG fridge
It is an error code. The thermal fuse in the freezer section has gone. It has to be replaced. To get by in the short term, uplug the unit for 15 minutes, then plug it back in. It will run until it hits the defrost again (approx 5 hours) Part location is 401A and part number is 6615JB2005C. It is easy to change once you get the back cover off. Plug in part.
Sgt 48
SOURCE: control panel on my fridge
Pull the power cord for 5 minute to reset the control board. if this control panel malfunction still exist after the reset, replace the control circuit board.
This is a typical control fault that should be corrected by pulling power for 5 minutes. if not, this reset will confirm major damaged to the circuit board.
SOURCE: I have a GE profile fridge model # PFS22S1SBSS.
I am surprised you were able to do diagnostics without the service manual or do you have one? I think you need to test each thermistor per test point on the motherboard. If the damper door is electric controlled then you must locate the thermistor that appears to be whacking out on you. My manual is about the only copy I have of GE's Artica/Profiles and I see yours appears to be bottom freezer. I think the thermistor is not signaling correctly and may be located near the auto vent. BRB
It's a mfi2269veb8. I've tried holding down alarm button and temp button and it says df sb...but I can't get anywhere else.
