Question about Garmin nuvi 2589LMT 5" GPS with Built-In Bluetooth, Lifetime Map Updates and Lifetime Traffic Updates
My Nuvi 2589 has jagged black and white horizontal when I try to power it on.
Posted by Karen Lavallee on
1 Related Answer
SOURCE: Screen display on my Garmin
I would suggest you reset the unit, if that doesn't solve the problem, then you will have to update your garmin nuvi, I think it needs to be updated. The unit is having a software issue. Usually, update helps to fix the unit's software problems.
Performing a Standard Reset
1. Slide the power switch all the way to the left (with the Nuvi's screen facing you).
2. Hold the switch in the position for at least eight seconds.
3. Push the switch to the right to power the Nuvi back on.
Performing a Factory Reset
1. Turn your Nuvi off by sliding the power switch to the left.
2. Press your finger against the bottom right corner of the touchscreen. Hold your finger in this position.
3. Slide the power switch to the right to turn the Nuvi back on. Continue to hold you finger against the screen until you see the factory reset prompt. Tap "Yes" to perform the factory reset.
Follow the procedures below on how to update your garmin nuvi:
1. Plug one end of the USB cable into your GPS and the other end into your desktop or laptop computer. The GPS device will load the appropriate driver automatically, and a message on your GPS tells you that it is connected to your computer via USB.
2. Open your Internet browser of choice and type in the following web addres: "http://www8.garmin.com/support/collection.jsp?product=999-99999-27 "
3. Download the appropriate version of the software for your computer (Windows or Apple) and Install the WebUpdater by following the wizard (accept defaults).
4. Click "Start," "Programs," "Garmin" and " WebUpdater" to update your firmware and your maps. Periodically check and make sure your software is current.
Also, in case you don't know how to reset your garmin nuvi, you can follow the steps below: There are two types of reset;
Regards.
Posted on May 16, 2011
I NNED HELP REGISTERING MY NEW GARMIN NUVI 2589 LMT
Just install Garmin Express on your computer and plug your device in.
http://software.garmin.com/en-US/express.html
Apr 17, 2017 • Garmin GPS
tip
TV shows either: black screen with: white vertical or, horizontal line
If Your screen shows a: white vertical line on a black screen or, a white horizontal line on a black screen:
Your TV vertical or, horizontal power transistor or, chip is getting too hot.
A vertical line indicates the horizontal circuit is at fault, a horizontal line indicates the vertical circuit is at fault.
To troubleshoot: Turn on your TV untill the line shows then: after about a minute, remove power (unplug) the TV, remove the TV back cover, find the too hot transistor or, chip; using component coolant; spray the too hot component with the component cooler until the screen comes back to normal. To fix: apply white coolant cream to the back of the too hot transistor or, chip. or, if there is room, a small fan can be wired in to cool the part. Radioshack sells the cream and, also a "component cooler spray" that should find and, fix this problem, also; with power removed you can, if you feel it is safe; carefully (with only one hand) feel the part; it will be very hot! (it could burn your finger!) Do not touch anything else! (this will not hurt the tv; when the picture comes back on (the offending part has cooled) you have found the problem part.
on Apr 06, 2010 • Televison & Video
I want to register my nuvi 2589 LMT
Go to the Garmin website. If you have an account, log in. If you do not have an account, then make one. The site will allow you to register your device onto your account. You can then download and install Garmin Express, which will provide you with any software and map updates. To use Garmin Express, just plug your GPS into your PC, open the program, and follow the instructions it provides.
1helpful
Sony trinitron KV27V22
Solder any / bad connects horiz,vert and power supply then
try again....................T.
Please rate this solution.........................
Garmin nuvi 2589LMT 5" GPS with Built-In Bluetooth, Lifetime Map Updates and Lifetime Traffic Updates Logo
Top Garmin GPS Experts
Tom Chichester
Steve P
Steve P
Aron
Are you a Garmin GPS Expert? Answer questions, earn points and help others
