Question about Russell Hobbs Blenders
My handblender is running only when my husband is pressing the button on the handblender harder with two hands that too with less power.how to open this and fix it?Thanks
Power comes on but when any of the other knobs are pressed it not coming on
Sounds like the safety button under the locking tab is not making completely - or the tab is broken.... Machine will not "run" without this safety tab making contact.
May 25, 2014 | Cuisinart Blenders
Blender was connected to 220V instead of 110V and ON button was pressed, I heard a sound and perceived burning smell, after opening the bottom i noticed a burnt component(Mica capacitor) with a diode...
More than likely you fried the boards and even if to change them out ,you still run the risk of electrical shock. My advice is to send it back to the company for repair or get a new one. Plugging a 110 unit into a 220 line has happened to me too! I still feel pretty stupid I did it, but stuff like this happens and it is good that you were not injured.
Dec 05, 2013 | Blenders
How to dismantle hand blender kenwood kmix?
hi there, i have one of these and am quite tech savvy and want open
the sucker up and see whats wrong. Just would rather open it with
minimum damage to the casing.
Is there a way i can private message you my email address?
thanks
Dan
Sep 03, 2012 | Kenwood Hand Blender Set kMix HB790, White
My Braun MR5500BC Multiquick professional handblender is now not working but I still do have all the accessories still intact. Is it possible to buy the motor part of the blender only?
I have a Braun Vario Model 418 hand processor - motor works fine but when attached to the blender, the blender shaft vibrates - if you look into the inside of the blender, the shaft is shaking - may be some support is missing. Can any one advise what can be done.
Jaya
[email protected]
Sep 15, 2010 | Braun MR 5550 M HC + BC MultiQuick...
Breville hand blender doesn't blend continuously
I have the same problem. Mine used to work, has only seen light use, and now it runs for about 1 second before it shuts off. Expensive POS. There don't seem to be any solutions either.
Nov 18, 2008 | Breville Cordless Hand Blender - Silver
Intelli blender will not work
Do you hear it hum when you try to turn it on?
If yes, remove the cup. Try again... if the motor runs, try moving the blade by hand. If it is seized, remove it and clean it to free it again.
If not, possibly blown windings on the motor or divider circuit (which supplies different voltages to the motor for the different blend speeds). Repair will be required in either case.
Mar 24, 2008 | Westinghouse WST2000 IntelliBLEND Work Top...
Blender is not doing anything
either the motor is inoperable, or is improperly wired. return it to the retailer. that is assuming you have the cup firmly seated before you try to operate the machine.also if the control panel has more than one speed make certain that only one button, or switch position is engaged
Westinghouse WST2000 IntelliBlend
I have had my blender sitting for over a year ( only used it once ) because of the same problem and asked my husband to take a look at it... he opened it ... cut the zip ties took the metal banding off ( note only one side of the motor has the metal banding). What you need to get at is behind the first (I think) resistor. Behind that is a thermal fuse (found at radio shack part # 270-1320 about $1.96). you will need some kind of tester to check the ohms going through it (should read zero) the bad one on mine read 334 ohms and you will need a soldering iron to put it back together. Actually a good project for someone who loves to tinker with this.
Aug 29, 2007 | Westinghouse WST2000 IntelliBLEND Work Top...
Blenders Logo
162 people viewed this question
Top Russell Hobbs Blenders Experts
Marvin
Marvin
ray gallant
Tom Chichester
Are you a Russell Hobbs Blender Expert? Answer questions, earn points and help others
