Washing Machines Logo
Joshua Barkdull Posted on Apr 11, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Washer Dryer Stacked Combo won't start and didn't drain properly.
I just bought my stacked washer dryer combo a few weeks ago and suddenly it's not working. The last load it ran never drained completely, there is probably 5 inches of water in the bottom. When I try to select a new cycle the lid locks and the washer beeps like its supposed too but nothing happens. Then after a few moments (maybe a minute) it gives up and unlocks the lid. Then does three beeps a few times. This is a top loading frigidaire washer/dryer stacked combo. The dryer still works fine. It's very odd. I have heard it may be the Lid Lock. But I don't want to spend the time and money replacing it if that's not it.
  • Official Brand Answer 2,267 Answers
  • Posted on Apr 19, 2016
Frigidaire
Level 0:
Answers
2267
Questions
0
Helped
1289526
Points
2557
Hello Joshua, thank you for your post!
From my understanding your Frigidaire laundry center is not starting and did not drain properly. It is possible that this could be a miscommunication within the laundry center and a reset may help clear that out for you. In order to reset your laundry center you would need to disconnect power from it for at least ten minutes. If that does not help your laundry center you may need to seek assistance from a professional technician for proper repairs. I hope this is helpful and if you should need further assistance please feel free to reconnect. -Matt
4 Related Answers
Anonymous
  • Posted on Aug 11, 2008
SOURCE: kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Anonymous
  • 35 Answers
  • Posted on Oct 15, 2009
SOURCE: Frigidaire stacked dryer/washer not draining water
pump is not working check the belt and pump
Testimonial: "thanks!"
TheMobilian
Dan Webster
  • 8221 Answers
  • Posted on Jun 22, 2012
SOURCE: Frigidaire Fex831cs Top Load Stacked Washer won't agitate
I worked on one last week which was completely dead. Some wires were cut. Took a few pics: Laundry Center repair
Service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
chrispolkele
Electrolux
  • 4342 Answers
  • Posted on Sep 25, 2012
Our people make the difference
    Verified Fixya Pro
    SOURCE: my Frigidaire FEX831CS Top Load Stacked Washer / Dryer goes through the cycle till it gedts to drain, then nothing... pump out?
    Hello trinileigh19 - Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose.
    I have a stacked Frigidaire, the dryer works perfect, but washer won't turn on.. doesn't make a sound of anything.
    About 6 different possibilities and most require tools, diagnositic instruments, and parts. Sorry, a service call looks inevitable unless you or a handy fixer uppper can tackle this. Here are the possibilities. Maybe you can eliminate a few of such and just get lucky. https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washer-Dryer-Combo/531-2--/Frigidaire-Washer-Won-T-Start\
    Jan 18, 2022 • Dryers
    Can an frigidaire X091307954 dryer be stacked on a Amana NFW7200TW 3.5 Cu. Ft. Front Load Washer?
    this is possible, youll need a kit that sets on top of the washer,check back where you bought the washer and dryer, they make a washer and dryer combo thats one peice, they are smaller however
    I have a stackable Frigidaire washer/dryer combo and the problem is that when you push the start button, you hear an electrical buzzing but the dryer won't start. When you take the panel off it st
    Hello Mike Brady - From what you have described it seems like the dryer is experiencing a wiring failure or a communication error with the control board. Contact a professional to move forward accurately.
    Kenmore stacked washer-dryer 41794802301 dryer wont start
    dryer working washer not for a kenmore 41794802301 washer dryer combo
    Water under stackable washer dryer
    The front panel comes off and you will be able to trace the water source. These combo units spin immediatly and if the drain is slow the water will spin up over the edge of the tub during drain.
    Eric
    1helpful
    How do I separate a stacked washer/dryer combo unit?
    Tried this before and is a major undertaking. The front angle panel has to be removed before you can access the rear panel, and then all of the electrical connections need to be traced and disconnected. This is a job for a tech and not recommended. I would suggest you measure, and then measure again and find a way to remove it in one piece, maybe even out a window if one is big enough.
    2answers
    Water leaking from stacker unit
    No parts are replaceable within the pump. Buy a new pump.
    Kenmore 98702 Stacked Washer/Dryer Combo Model 417.98702890
    There is an EXTERNAL fuse on the back of the unit.
    Service manual is inside the machine's shell in plastic.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Top Frigidaire Washing Machines Experts
    ZJ Limited
    ZJ Limited
    Mike Cairns
    Mike Cairns
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
