Question about Measuring Tools & Sensors
Acurite weather forcaster not showing outside temp
Everything works great just want show outside temp
Posted by Wanda Blair on
  • Wanda Blair Apr 10, 2016
    already have the manual says use energizers and that's what I'm using
Morgan T Bradshaw
    Habit-Forming:
    New Friend:
  • 86 Answers
Here's the manual for the AcuRite Weather Forecaster. If it's not showing the outside temperature, make sure the A-B-C switch is set to match the display unit. Not doing so might be the reason it's not synchronizing and displaying the outdoor temperature. https://www.acurite.com/media/manuals/75077-75107-instructions.pdf
Posted on Apr 10, 2016
I have an Acurite weather station, model 02080, and when I place the lightning sensor outdoors as it states in setup, outdoor temp is indicated. How do I set it up to work properly?
The display has the internal sensor for temp and barometer, The 5 in one has the sensor for outdoors and shows temp, wind speed and direction, humidity and rain. With the added lightning detector having the additional temp sensor in it, the system is redundant. It is recommended to put the sensor outside for best results that t have the least interference and maximum range..
Apr 01, 2018 | Measuring Tools & Sensors
Acurite 436 shows temp at -18 consistently
You will need to return that or order another one. There is nothing you can do about recalibration or other maint. You could bring it inside to compare it with the temp on the inside unit.
Oct 22, 2016 | Measuring Tools & Sensors
The indoor temp on my acurite model 02086 weather stn. constantely reads 26c how do I get it to read the correct indoor temp?
The manual of unit will tell you how to change reading from Centigrade to Fahrenheit. Read it carefully for details.
Oct 02, 2016 | Measuring Tools & Sensors
Model 00754W4 does not sense outside temperature..new batteries have been placed correctly in both inside and outside units..noW what do I do?
We would recommend a reset of your unit. Please verify that you are using good-quality, standard alkaline batteries such as Energizer or Rayovac, then follow the steps below.
1. Bring both the sensor and display unit indoors and remove at least one battery from each.
2. Make sure the A-B-C switch on both units match. Sometimes changing to a different channel can help.
3. Reinstall the battery in the outdoor sensor.
4. Reinstall the battery in the display unit.
5. Let the units sit within a couple feet of each other for about 20 minutes to gain a strong connection.
If you need any further assistance, please contact AcuRite Customer Support at 1-877-221-1252 or [email protected]
Dec 03, 2014 | Acu-Rite Acurite Wireless Indooroutdoor...
Next tech weather station is. Not w
Try taking the inside unit outside as close to the transmitting unit as possible for three minutes. The signal might lock on to the setting you want to receive.
Jul 01, 2014 | Acu-Rite Acurite Wireless Weather...
No longer shows temp (indoor or out) or weather. Outside unit is still working and showing temp.
Mine did the same thing. I just had to replace the batteries in the main unit and it is working again. Good luck!
May 22, 2011 | Leeds 805058 High Sierra Tahoe InOutdoor...
I have an Acurite 822-RX thermometer that shows HH as the outdoor temp, even after replacing the batteries in both the base and remote units. How can it be fixed or reset?
HH means it is showing the high temperature you (most likely accidentally) set with the MAX MIN / + button, which is easy to do when setting the clock. Just press that button again until the reading appears.
Jan 15, 2011 | Acu-Rite Acurite Wireless Weather...
I put new batteries into both units, the indoor unit and outdoor unit, now it is not able to read the outdoor temperature. What needs to be done?
I'm having the same problem and can't find an answer. Seems this also happened with another model we had - planned obsolescence? It was working fine, flashing due to low battery. Now, nothing from outside. Annoying.
Oct 16, 2010 | Acu-Rite AcuRite IndoorOutdoor Wireless...
Measuring Tools & Sensors Logo
1,772 people viewed this question
Top Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
