It looks like the photos aren't even registering in the phone memory anywhere. when i check my phone usage it says the app only has 85mb of data only an hour ago was about 3GB. maybe i'm being naive but how is it possible for iPhone to just delete data without your approval?
It's wired. You can have a try Leawo iOS Data Recovery to recover the deleted photos on iPhone. Just follow the below steps.
The following guidance will introduce how to recover photos from iPhone backup and iCloud backup with Leawo iOS Data Recovery, and you can free download the program to have a try.
Section 1: How to recover deleted photos from iTunes Backup
Step 1: Select Recover from iTunes
Run Leawo iOS Data Recovery and choose Recover from iTunes Backup.
Step 2: Scan iPhone Backup
Select the iPhone backup and click Scan at the right bottom.
Step 3: Select Photos to Recover
Check Camera Roll and select the photos you need. Then click Recover.
Step 4: Choose Target Folder
Click Open in the pop-up dialog to choose a target folder on your computer. Then click Go to start recovering photos from iPhone 6 backup.
Section 2. Recover Deleted Photos from iCloud Backup
Step 1: Choose Recover from iCloud
Run Leawo iOS Data Recovery and choose Recover from iCloud Backup.
Step 2: Log in with Apple ID
Enter your Apple ID and log in.
Step 3: Select iPhone Backup
Select the iPhone backup and click Download at the right bottom.
Step 4: Select Photos to Extract
After the program downloaded the backup, check Camera Roll and select the photos you need.
Step 5: Choose Target Folder
Click Open in the pop-up dialog to choose a folder on your computer. Then click Go.
When the recovering process is done, you will get the photos in the target folder. The photos can be imported to your iPhone X again with no efforts.
Actually, with Leawo iOS Data Recovery, you could not only recover deleted data and files from iPhone, but also export data and files from iPhone to computer as backup, such as exporting iPhone notes to computer. Unlike iTunes that will store all data and file from iPhone to computer, Leawo iOS Data Recovery allows selective data and file backup, which is much more convenient.
For more details, check: How to Recover Deleted Photos from iPhone
SOURCE: Phone Memory
i also got the same problem for 4 times already. for the 1st time, i went to the store that i bought the phone and he said my phone got a virus so he fix it and i had paid 50dollar. but when i got the same problem for the 2nd and 3rd time i just took out my sim card and put another simcard and just wait a minute then i will put back my simcard and it works. i dont know how it happens but it works. =D . When the same problem happen again for the 4th time it doesn't work anymore even though i tried for more than 10 times. so i try surf in the internet on how to reformat N73. then i found this way :
1- type *#7370#
2- the phone will ask a lock code then give your lock code
3- then ur phone will be reformat
try this! it really works! just take less than a minute and it's free..trust me! =D
GOOD LUCK!
SOURCE: How to delete some data in my nokia n73?
Try to delete songs or setups that you might have kept in the phone memory (c:) drive of your phone !
and make sure no application is running in background before opening LifeBlog.
For better viewing of the files kept in the phone memory use X-PLORER software !
It rockx.
Thanks
SOURCE: even after hard formatting the phone memory, my
Switch-off your phone. 1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone. Remember, do not let go the 3 press and hold keys until you see a formatting word screen show! 2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
