SOURCE: Ford Fairmont au 2000 mod.
3 fuses involved. 9 & 13 feed power to radio, 15 feeds power to antenna. All located in fuse box
SOURCE: Hi, please can I get complete instructions on how
first you go to the welder have him weld some tabs on the frame there is no fromt structure in the car it will require a welder
option 2 buy a light duty car dolly it will lesson the strain on the trans and tront end allowing you do get an extra 50 k out of your baby just remember if it is flat towed your only saving the motor milage but the trans is still working along wit all the front drivweline cv's rotors calipers struts and tire wear too from those tight corners you had to drag it arround
SOURCE: 2000 au ford falcon sedan door locks chatter when
If they aren't locking and unlocking properly, or are jumping, it is probably a broken worm gear in the door lock. You can buy new ones on ebay.
SOURCE: Ford Falcon Sedan AU model. The blinkers staying on
The flasher relay can get stuck. It is usually a 3 pronged, small, cylinder or cube plugged into the fusebox.
