Are drivers considered firmware? My windows 10 tablet suddenly lost the drivers for touch input and other drivers I need to reinstall the drivers so that my computer will work properly again
Posted by Damon Toney on
  • Damon Toney
    Damon Toney Apr 09, 2016
    by the way I've already contacted RCA and went to the RCA website where you have to request the drivers but RCA still has not responded to my request as they don't seem to be a very good customer support company
Cyril Brian
    New Friend:
  • 43 Answers
The driver also need to be updated when the Windows system is udpated. You can try to find compatible driver from the device official website. Besides, it is better for you to use this way to download and update drivers for Windows 10.
Free Windows Driver Update Get the Latest PC Drivers
Posted on May 12, 2016
Ravi
  • 1,682 Answers
Generally No. Firmware is NOT the driver.
The driver is normally a software specific to os.
There could be an application layer over and above the driver to interface to user.
Windows 10 should recognize the device when connected by USB and install the driver automatically.
Posted on Apr 09, 2016
5 Related Answers
Anonymous
SOURCE: RECURRING PROBLEM OF WACOM TABLET GETING STOPPED
Unplug the tablet and then plug it back in. This sorts it for me.
Posted on Jan 12, 2008
Anonymous
SOURCE: Wacom Intuos3 Tablet driver crash in photoshop
I was having the same problems, it only occurred when i updated the tablet driver to v. 5.2.1-6. So i've downgraded to the one that came with my graphire3 (tablet driver v. 5.2.0) ...hope this helps
Running: OS Win7 PS CS3 Wacom Driver v. 5.2.0 for Graphire3
Posted on Jan 19, 2010
Anonymous
  • 6 Answers
SOURCE: My wacom tablet has loses connection
You should get the tablet, and then get some tape, and then move around the wire, and then when it turns on, tape it onto the tablet, and then it should work intill you take off the tape.
Posted on May 05, 2010
Testimonial: "Thank you! Since posting I had determined that it was a wire placement issue and I have been managing. But, I will definitely tape it and see how that goes!"
Anonymous
SOURCE: Wacom tablet stopped working, blue light on.
Hey I had this problem too with my Bamboo too, I'm not sure if it was anything I changed or whatever but either way the blue light was on but it wasn't registering the pen.
I found a way just minutes ago to fix it however!
Go into 'start', 'all programs', then look for 'pen tablet'. Hopefully you should have this. If not then download the latest driver for your tablet from the wacom website and that should install it.
Next choose 'pen tablet preference file utilty'. Then under 'my preferences' choose to remove. Bingo! All was well in the world again.
This worked for me so hopefully it will for some of you guys too! Good luck!
Posted on Jul 11, 2010
Anonymous
SOURCE: "Insecure Startup Item Disabled" What do I Do?
Did you find the solution to this yet? I have the exact same problem with my Wacom tablet.
Posted on Sep 21, 2010
I installed windows 10 on my mecer a105 tablet,the touch screen is no longer working and also it doesnt detect the sim card and no sound at all.
Is your tablet capable of running Windows 10? Put the old OS back on it. Tablets need special drivers for the touch screen and drivers for the sound card specific to that tablet. Contact the makers and say you need the original operating system and drivers.
Nov 13, 2016 | Tablets & eReaders
SCREEN TOUCH NOT WORKING WHAT CAN I DO ?
1.- Run Lenovo diagnostics and look out for hardware errors.
2.- Reinstall screen and input drivers.
3.- Take it to a lenovo repair center.
Nov 09, 2014 | Lenovo Yoga 10 10.1 inch Tablet with 16GB...
Supersonic 7" touch screen MID Tablet
You need to flash new firmware you can download LiveSuit and
then look for the correct firmware that is compatible with your tablet.
If you search for How to Flash Tablet there will be a video or instruction on how to do it.
Jan 15, 2014 | Supersonic 7" Touch Screen MID Tablet
Compaq tc4400 suddenly turned into non tablet pc (pen & touch gone)
http://www8.hp.com/us/en/support-search.html?tab=1#/qryterm=compaq%20tc4400&searchtype=s-002
this is where your find the moel drivers for tablet , there are two available , so please read before installing.
Nov 27, 2013 | Compaq tc4400 Tablet PC
I have a Toshiba tablet M780-s7230 and i tried reinstalling the touch screen driver and my tablet pen and touch screen still don't work what else could i do?
Have you turned on the Touch feature on Windows 7 yet? That could be the reason why your touch screen feature is not working.
To turn it on please follow this:
1. Open your Start menu and type "Touch" into the search bar. This will show a variety of options, including the "Pen and Touch" options. Double-click it to open the "Pen and Touch" window.
2. Check the boxes next to the "Use your finger as an input device" and, if preferred, check the "Enable multi-touch gestures and inking" box as well.
3. Click "Apply" to set the options and click "OK" to exit the window.
Hope this helps!
Apr 10, 2011 | Toshiba Portege M780-S7230 Tablet PC
Hp pavillon tx1000 12.1 inch touch screen cursor stays at bottom left hand conrner
Clean the screen with a clean soft cotton cloth is the step #1
Step 2:
SEE FULL instruction HERE
Calibrate the touch screen
The command buttons and fields are displayed on the screen image at specific pixel points. To initiate a response, the touch screen interface needs to recognize exactly where a fingertip or pen touches the screen relative to the pixel position of the display. Each user has a slightly different hand-eye coordination response. Calibrating the touch screen allows the interface to compensate between where the program is expecting a touch and where the touch actually occurs. To calibrate the touch screen, place the tablet notebook in the desired orientation and do the following actions.
  1. Click or tap Start > Control Panel > Tablet PC Settings to open the Table PC Settings window.
  2. On the General tab, select the option to display the menus in either the Right-handed or Left-handed position.
  3. On the General tab, select the desired screen orientation from the drop-down menu, and click or tap Calibrate . Follow the instruction to touch the screen at the specified points. Repeat this calibration action for all four of the screen orientations, then click or tap Apply .
  4. On the Handwriting Recognition tab, select the Use the handwriting personalization option.
  5. At a later time, you can return to review the Go to Pen and Input Devices and Go to Input Panel Settings options to make using the touch screen to control programs and input text easier and more accurate.
Compare your version of the firmware to the latest one at HP offical site HERE
Always get the latest firmware to avoid problem.
Always keep the screen clean!
Jul 11, 2010 | HP Pavilion TX1000Z 12.1" Touch Screen...
Upgrade firmware problem zen touch 20 gB
I contacted Creative about a similar problem with mine when I went onto Vista and they advised that I had to update the firmware. The downside they stated was that I would probably lose all my songs. The only way round this is to save them all to a non vista computer and then upgrade and hope you can put them back onto your player. Here is the info they sent me. Not sure if it works as I never got round to it.
I understand that you cannot get the software to work in your Windows
Vista.
With regards to your enquiry, there are two things that you need to
consider, player and the software.
For a proper set up, you should update the player with an MTP Firmware
version using a PC with Windows XP installed.
What is the MTP Firmware?
http://uk.europe.creative.com/support/kb/article.asp?l=3&sid=6773
Ensure that computer has both Service Pack 2 and Windows Media Player
10.
a. Verify SP version, click+Start+Run+type Winver.
Next, update the driver first, once it has been installed, connect the
player then click the MTP firmware program.
Proceed to this link and download the following files needed.
http://uk.europe.creative.com/support/downloads/
just click on the link above then type the filename of the
driver version : JB3MV2_PCWDRV_US_2_01_00.EXE
firmware version : ZenTouchP4S_PCFW_LB_2_11_01.exe
at the search box provided.
download and save them to your folder. Click the program and follow
further instructions during the installation.
For instruction on updating the firmware, please use the link below and
select ZENTouch
http://uk.europe.creative.com/support/kb/article.asp?l=3&sid=4789
As for the software, you maybe required to download and install the
following updates below:
Please view important notes written at the website for further
information.
Proceed to this link http://uk.europe.creative.com/support/downloads/
then type the filenames: CMS5_PCAPP_LB_5_10_38.exe
CMS5_MTP_PCAPP_LB_5_00_36.exe
at the search box provided. Ensure device is attached before you start
the installation.
Sorry it's so long winded and I hope it works.
Andy
Jan 02, 2009 | Creative Labs Zen Touch MP3 Player
Creative Zen Touch firmware problem
Before preceding, goto control panel, add/remove programs (vista equivalent) select windows media player and uninstall note the response it gives you. If it is going to allow you to uninstall OR downgrade windows media player to version 9 then keep going. If not, then find another computer that you've never used the player on try upgrading firmware there, make SURE it's got windows media player 9 by downgrading it in add/remove programs.
Now for the fun stuff:
Sounds like the same problem I've resolved several times in the past on here.
1. Plug in the device.
2. Goto device manager in control panel and remove the device drivers.
3. Reboot if it asks you to, make sure to unplug the device.
4. Goto device manager again, remove the USB hubs.
5. Don't reboot.
6. Goto control panel, add remove software or equivalent for windows vista ultimate.
7. Select creative labs, and uninstall any and every zen related software.
8. Don't reboot.
9. Goto my computer, find the creative directory located on your main hard drive at \program files\creative. Deleted it completely.
10. Select windows media player select uninstall, or downgrade accordingly.
11. Make sure your zen touch is not plugged in and reboot your system.
12. After system loads, plug in the device and run the firmware software again.
And if you wish, reinstall windows media player 10 and the creative software (which you don't need at all with vista) all the other drivers should reinstall themselves.
BTW it's a hell of alot easier to just use another CPU if you have access to one, I've done it both ways and it saves alot of time.
Mar 15, 2008 | Creative Labs Zen Touch MP3 Player
Jan 15, 2008 | Wacom (PTZ930AC) Graphic Tablet
Loosing pressure sensitivity
I was trying also, didn't work at all, and I'm going to try to close and open Adobe Photoshop CS2. But I need it to work on a few adoptables! I need it NOW!
Nov 29, 2007 | Wacom (PTZ930AC) Graphic Tablet
Computers & Internet Logo
922 people viewed this question
Ekse
Marvin
Marvin
