Jensen VX7020 6 2 Inch MultiMedia Bluetooth Logo
Question about Jensen VX7020 6 2 Inch MultiMedia Bluetooth
Clock keeps resetting back an hour after I change it. How do I get this to stop?
Posted by mike puleo on
  • Jensen Master
  • 19,166 Answers
Check the settings for time zone and DST
Posted on Apr 08, 2016
How duo I change the time on my Sterling & Noble wall clock? It does not have any dials on the back to turn?.
To change the time on a Sterling & Noble wall clock that does not have any dials on the back, you will need to follow these steps:
  1. Locate the small, round hole on the back of the clock. This is the reset button.
  2. Using a small object, such as a paperclip or a toothpick, press and hold the reset button for about 5 seconds. This will reset the clock and allow you to set the time.
  3. Release the reset button, and the minute hand will begin to move around the clock face. Use the reset button to advance the minute hand to the correct time.
  4. Once the minute hand is set to the correct time, the hour hand will begin to move around the clock face. Use the reset button to advance the hour hand to the correct time.
  5. Once the hour hand is set to the correct time, the clock will begin to run normally.
I hope this helps! If you have any further questions, don't hesitate to ask.
I have a grandfather clock on foot, but since the change of time this year it does not ring anymore how to repair it
I would hope that when the time change happened that this clock was not turned backwards. To set these clocks back the pendelem should be stopped and restarted one hour later.I was told you should take the clock to a clock repair shop to get it reset.
Nov 19, 2018 • Home
How to reset the clock?
Hello Ruth Anderson,
All mechanical... clocks (even quartz) should only ever be ADVANCED... In the springtime simply advance the clock and HOUR. In the FALL pull the plug, stop the pendulum...
QUARTZ WATCHES... Pull the winder stem out FULLY
(this removes battery...
Wait an HOUR... Plug the clocks back in... restart the pendulum
or push in the STEM on your QUARTZ WATCH...
(this restores power (and keeps the CROWN from coming unscrewed from the "winder-stem")).
Never turn the clocks backwards...
Modern clocks probably don't ACTUALLT MATTER
but antique clocks and timers can be UTTERLY RUINED
(It's just a good rule... & water RESISTANT seals happy).
Relative to the clock-face...
"FALL BACK - SPRING FORWARD"
SPRING = FORWARD ... advance the hands an hour.
Technically "time change" only ever occurs between
1am and 2am during each time zones respective hours...!!
Even on QUART
Hope this helps!
1helpful
How to reset clock chimes
The hour hand is a friction fit, so you can probably just remove the clip or cotter holding the minute hand in place, pull off the hour hand and set it back to match the chimes. The minute hand is on a square shaft, so if you are off by a 1/2 or 1/4 hour, you can change its position also (but only in 15-minute increments).
Jun 25, 2014 • Home
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
1helpful
Sangean h2o1 clock is flashing. The radio display doesn't flash - only the clock. I've reset the clock, changed the batteries, and generally played with the other settings. Can't figure out why the time...
Here's the thing: When you change the batteries, the radio thinks you need to reset the time, even though the time has been preserved and is correct even after you change the batteries. Here's what you do: Pretend you need to reset the time. With the radio off (recommended), press and hold the "Band" button with the "set" notation underneath it. The hour will flash. "Reset" the hour by using the tuning buttons, as you would if the radio were new, and then change it back to the correct hour. Press the "Band" button again and repeat the process for the flashing minute display. Press "Band" again to end the process. You will have successfully fooled the H201 into thinking that you have reset the time, and the time display will have stopped flashing. (This does not appear to work if you do not actually pretend to change the hour and minute and just keep pressing the "Band" button -- you have to go through the procedure as though you were actually changing the time.)
2answers
How do i reset clock for the taylor clock timer 5851-21?
my Taylor 5851-21 has Hour Min Then under thatt Timer/Reset abd Start/Stop. How do I set the time. I know how to work the timer and reset the timer, but I need to set the clock. But it does not have a clock button label as you describe above.
1helpful
1985.5 PORSCHE 944 digital clock (changing time)
There are three buttons, let's call them 1, 2, and 3, from left to right.
Clock
Time setting
A. 12 AM, PM or 24.00 h
With the clock in the time readout mode, keep
button (2) depressed for 4 seconds -12 AM, PM
or 24.00 flashing. After pushing button (1), either
a 12-hour (AM + PM) or a 24-hour setting
program can be selected. If you only want to
change the display mode, push button (3). The
clock then returns to its normal timekeeping
function.
B. Hours
Push button (2) a second time - hour display
flashes. Set hour by pushing button (1). After
pushing button (3)*, the clock returns to the time
readout mode with new hour setting.
C. Minutes
Push button (2) once more - minute display
flashes. Set minute by pushing button (1). Upon
pushing button (3)*, the clock is started -
accurate to within 1 second.
Stop watch function
The stop watch can only be set in motion if the
clock is in its normal timekeeping mode and not
during setting operations.
A. Push button (3) - 00:00 display appears;
B. Push button (1) - stop watch is on;
C. Push button (1) a second time - watch stops.
(Additional times can be added by pushing button
(1) again - stop watch keeps running. Push button
(1) once more to stop timing.)
D. Push button (2) - 00:00 display appears;
E. Push button (3) - normal timekeeping mode.
If button (3) is pushed during operation A and
B, the setting procedure must be restarted
How to reset Time clock on NEC MT830+ Projector
change the lamp even if the old lamp
use original nec remote contro
l6. After you install a new lamp, select the lamp Usage icon and press and hold
the "Power On" button on the remote control for ten seconds to reset the
lamp time clock to zero.
NOTE: If resetting the lamp clock back to zero after 2100 hours of service,
press the "Power Off" (not "Power On") button on the remote control for ten
seconds
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
