I replaced the solenoid and battery and the whole time with mine it was a loose ground cable to the motor frame tightened it back up and off to the races. Hope this helps somebody out. Also works on gas golf carts as well.
If you can move the flywheel or main pulley by hand the engine is not frozen, so its starter, solenoid or battery or connections to the starter or battery. Usually dead battery of corrosion on the terminals. Jump the battery to test using known good cables. Sometimes going straight to the starter with the cables is a necessary test to bypass hidden connection rot. Having lights is not a good test of battery capability.
