Question about U-Line Refrigerator Ice Maker
What is the +&- ***** for on the u line ice maker
Posted by Elva Masters on
How can obtain a manual for the Savoureux pro line portable ice maker
SAVOUREUX PRO LINE Ice Cream Maker - Fixya
www.fixya.com/.../p12370933-savoureux_pro_line_ice_cream_maker Recent SAVOUREUX PRO LINE Ice Cream Maker questions, problems & answers. Free expert DIY tips, support, troubleshooting help & repair advice for all Ice ..
Not making ice and not getting water to ice maker
Has the ice make r been working and then recently stopped?
Is there a filter in line with the ice maker?
Is there a shutoff on the water line feeding the ice maker?
Water line from house supply sprung a leak just before going into the ice maker control unit in the lower right cornor of the frig. After replacint the water line the water did not flow into the control...
What once was a leak is now no flow and no response when trying to turn on ice maker? Is the valve where the ice maker line taps into turned back on? If it's back on, first turn it off, take loose water line as close to ice maker as possible, then have someone else turn valve at tap slightly on while you watch for water flow. If no flow, start back-tracing your connections until you find the blockage. Most water connections of this type have a in-line filter. Is it clogged? If you have water pressure as close to the ice maker as you can test, next you may need to troubleshoot the ice maker it's self. Let me know?
Hooked up water line and ice maker, water working notice maker. Any ideas?
Make sure wire loop extending out from the ice maker over the ice bin is pushed down. Up turns the ice maker off.
Without more info, I can't diagnose further.
Stick finger in ice tray where ice freezes. Is there water in there. No, check solenoid valve and water line to ice maker (kinks). Is there ice cubes in ice tray? Is ice maker pushed fully in? All wires to ice maker on back and underneath connected?
If this information was useful, please select YES to the first two rating questions. Good Luck and thank you!
3helpful
Ice maker not making ice. do have water, no ice
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
The ice maker has completely stopped producing ice
The ice maker is producing ice poorly
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Ice maker not working water working
somtimes the line to the ice maker frezes.you could test by putting 110 volts to the water valve direct[or inspect]water should then enter ice maker .your post dosent say your brand but most ice makers you can start by pulling on the harvest rake till starts.[mechanical only] if water valve good and line not frozen .then could be loss of power to ice maker[check at ice maker plug in at frezer] if thats ok then ice maker has failed,replace God bless,tom
1helpful
Water solenoid to ice maker not working. Check with ohm meter..should NOT read open
Water line to Ice maker frozen solid. Look at water inlet to ice maker....is ice present in line?
Evaporator coils frozen over with ice. Will cause water line to freeze and unit will slowly thaw.
Try unplugging the unit for several hours and see if it starts to cool normally again. If it cools normally then check heater element and Defrost Thermostat.
Ice maker
read the mamual
U Line Origin Series BI95 14" Ice Maker with 12lbs. of Ice Storage, 23lbs. Daily Ice Production & No Drain Required "The difference is in the details. Take a closer look." Compact andconvenient, the Origins BI series offers both streamlined styling andADA compliance. As developers and manufacturer of the world's firstbuilt-in undercounter residential and light commercial ice maker,U-Line maintains its posi ... More
HOOK UP OF ICE MAKER TO THE WATER LINE
The ice maker is not making any ice, or water or crush ice. The wheel that crushes the ice will not spin. Please help
U-Line Refrigerator Ice Maker Logo
Top U-Line Refrigerators Experts
Dale Copeland
Dale Copeland
Kardoc
Tom Chichester
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
