Question about Russell Hobbs Blenders
How can I repair?
The blender buttons seems loose and it suddenly stopeed working
jonathan tones
    New Friend:
  • 8 Answers
Your best bet is to open it up carefully and investigate. It's usually a minor problem unless it is old. Check it out yourself, you can't break something that's already broken and you'll gain some knowledge! :D
Posted on Apr 08, 2016
Reset button blender
If they do have a reset button it is normally underneath.
Aug 26, 2013 | Vitamix Blenders
The gear at the base of my waring bb 180s blender is stripped
You can try the sears online parts store for help they may be able to get the parts you need as they are pretty much the same. iF YOUdon't find it let me know and I will resurch it for you and find the part it is eather the druve nut has come loose or the teeth on the plastic shaft has worn off, it is possible to super glue it to hold if you cant find the part.
Nov 12, 2009 | Waring BB180 Work Top Blender
The blender and lcd countdown is on...blender
If so, it's underneath the unit. If so, unplug it before resetting.
Oct 06, 2009 | Breville CBL10 BlendMaster Classic Work...
All of a sudden my fairly new blender does not go on.
hello mam
there are chances of burning of the field windings and the commutator of the armature the blender and also check for any loose connection at the carbon bushes of the motor(inside the blender)
Jul 29, 2009 | Waring MBB518SS Professional Work Top...
Unit seems to work fine, but when the pitcher is attached, the blade hardly spins. It seems like it is loose or something. I can manually spin the bottom piece of the blade assembly, but the blade itself...
Depending on the age of your blender, a new blade assembly may be available. I would recommend calling Kitchenaid Customer Service for pricing. Their toll-free telephone number is:
1.800.541.6390
Jul 27, 2009 | KitchenAid KSB3 Classic Work Top Blender
I was using my blender and it suddenly stoped working but the ligths are still on hamilton beach blender 59207
1 check for burned fuse .
2 often the brushes that are in contact with the inductor get worn you have to replace them ( 2 brushes).
jrico39
Mar 07, 2009 | Hamilton Beach 59207 5-Speed Blender
I have a Kitchenaid blender model KSB5BU3 marked "Ultrapower" and "Electronic Control" on the side. Suddenly all the buttons started blinking together after we pressed the On button and then one of the...
When the lights are flashing, this does indicate that an electronic part has failed. This blender is no longer manufactured, so finding replacement parts for it may not come easily. Repair centers are available. I would recommend calling Kitchenaid Customer Service to see what they can recommend for you.
Their toll-free number is 1-800-541-6390.
Jan 10, 2009 | KitchenAid KSB5 Ultra Power Work Top...
My nblender just stop working, power in was good, no reaction.
Switch must be bad, remove the four screws on the bottom they are under the feet, then check switches, and replace broken one.
Nov 19, 2008 | Vitamix 5000 Work Top Blender
Blender won't work
This indicates an internal problem with the blender itself as pertaining to the motor. I would suggest contacting Kitchenaid Customer Service to see about having the blender repaired or possibly replaced.
Their toll-free phone number is 1-800-541-6390.
Also, a listing of Kitchenaid certified repair facilities may be found at the following link:
http://caservice.kitchenaid.com/
Sep 06, 2007 | KitchenAid KSB5CR Chrome 5 Speed Blender
Blenders Logo
187 people viewed this question
Top Russell Hobbs Blenders Experts
Marvin
Marvin
ray gallant
Tom Chichester
Are you a Russell Hobbs Blender Expert? Answer questions, earn points and help others
