Hello Mike, it would be easier if you mention the brand and the model of your alarm clock radio, to be able to find the simplest solution.
I wait your answer
Greetings Franco Dosil
Hola Mike, seria mas sencillo si comentas la marca y el modelo de tu radio reloj despertador, para poder encontrar la manera mas sencilla de soluci?n
Espero tu respuesta
Saludos Franco Dosil
You can download the complete user manual which has the detailed instructions for setting or turning off alarm by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view this manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
Setting the Clock: 1. Press the SET Button 3 times until all digits for the main clock are flashing. 2. Press Skip forward and back to change the hour and Volume up and down to change the minutes. 3. Press the set button once to save.
When you set the alarm you pressed aburron that said 'radio' and/or 'buzzer' then programmed the time. Just press the buttons again and the alarm will no longer sound. Looking at the dial at the top of the lcd screen you will see the word buzzser or radfio if the alarm is enabled. Pressing buzzer or radio on the side will remove the word and no more alarm!!
Disable the alarm permanently1. Press CANCEL button.2. The corresponding WAKE indicator willbe flashing.3. Press WAKE 1 or WAKE 2 button within3 seconds to deactivate the correspondingalarm function permanently.
