Question about Staples SPL-P100 Printing Calculator
Why are totals rounding off
When I add numbers and press total I only get whole numbers - there are no decimal places showing
Posted by Debra Featherby on
paulgbrandon
  • Staples Master
  • 654 Answers
In the product details of this calculator, it states that there is a "decimal point selector." This is normally a slider starting with the letter F followed by the numbers 0123 etc. It is probably on 0. You can set the number of decimals to whatever you want, or use F for full numbers. For example, if you set this to 2, you should always get 2 decimals.
Good luck,
Paul
Posted on Apr 09, 2016
HP 12 C display does not show entire numbers. How do I fix?
If you mean it is not showing everything after the decimal point, you can change that by pressing the [f] key followed by the number of decimal places to display. For example, to restrict it to 2 places, press [f][2]. If you want to see 4 places, press [f][4].
To show all possible decimal places, use the sequence [f][9].
From the manual (http://www.hp.com/ctg/Manual/c00363319.pdf):
"To display a different number of decimal places, press f followed by a digit key (0 through 9) specifying the number of decimal places. In the following examples, notice how the displayed form of the number inside the calculator - 14.87456320 - is rounded to the specified number of digits."
25096057-rvrejqbjq4zuw4cbinsyjvsy-5-0.png "Although nine decimal places were
specified after f, only eight are
displayed since the display can
show a total of only 10 digits. "
The standard display format, plus the specified number of decimal places, remain in effect until you change them; they are not reset each time the calculator is turned on. However, if Continuous Memory is reset, when the calculator is next turned on numbers will be displayed in the standard display format with two decimal places
shown.
If a calculated answer is either too small or too large to be displayed in the standard display format, the display format automatically switches to scientific notation. The display returns to the standard display format for all numbers that can be displayed in that format.
Sep 12, 2014 | HP 12c Calculator
Is their away to round whole number on a ti30 calculator
To do this you need to set your calculator to a fixed decimal value. You can do this by Pressing 2nd + FIX (decimal point) and then setting it to 0 decimal places. This will round a number to the nearest whole number.
Hope that helps.
Apr 22, 2011 | Texas Instruments TI-30XA Calculator
Can't find a manual online. What does 5/4 mean, and how do I turn it off? Same for E. My biggest problem is that when I add up numbers with the print function on (for depositing large batches of...
The manual for the Canon P1-DHV is online at http://www.usa.canon.com/app/pdf/calculator/P1-DHV_G_USA_HWB.pdf>.
When the display shows "5/4", the calculator is doing 5/4 rounding which means: 5 or above round up, 4 or below round down. To control rounding press the "5/4" key.
When the display shows "E" the calculator could not complete a calculation. It can be because of dividing by 0, or because the total exceeded 1 trillion, or because the operator entered calculations faster than the calculator could complete them. Press the CI/C key to clear it.
I can't explain why you are not getting a total on the tape. Try the following example from the manual exactly as shown, and let me know if your tape shows the total.
  1. Clear the calculator (press [CI/C])
  2. Choose 5/4 rounding (press [5/4] until "5/4" displays)
  3. Choose add mode (press [DEC] until "A" displays)
  4. Choose cost-sell-margin mode (press [B-T] until "B" displays)
  5. Turn printer on (press [PRINT] until "PRINT" displays)
  6. To calculate: $12.55 + $15.75 - $5.30
  7. Key in: 1255 [+] 1575 [-] 530 [=]
  8. Tape shows: [0. C] ... [12.55 +] ... [15.75 -] ... [5.30 =] ... [23.00 *]
Apr 07, 2011 | Office Equipment & Supplies
How can I change the setting to print total the decimals. It is rounded off to the nearest one hundred.
You need to set your decimal selection to full-floating if you expect any numbers to be more than 4 decimal places.
Each time you press the DEC key it changes the decimal selection. From F to 0, 2, 3, 4 and A in that order. F is "full floating" but appears as a blank on the screen. A is the "add-mode" for currency transactions. The "A" does show on the screen if this is your selection.
As soon as the letter for the number of decimal places you want ("F" is blank just before 0 decimals) appears on the screen you are "ready to go." Problem is, the decimal indicator numbers and letters are so tiny and screen is so difficult to read that under many lighting conditions your selections might be all but invisible. They are in the upper left side of the screen just to the right of the equally difficult to see multiplication and division rounding indicator "5/4." PS If the 5/4 does not appear on your screen then you have set the round-off function to not available.
Feb 26, 2011 | Canon P1-DHV Calculator
Where do I go to find an on-line manual for TI 5045 Sv Texas Instruments calculator?
TI-5045 SV
ii
English.............................................................. 1
Fran?ais ............................................................ 6
Espa?ol ............................................................. 11
Portugu?s ........................................................... 16
Examples, exemples, ejemplos, exemplos .............................. 21
ILLUSTRATIONS ¦ FIGURES ¦ ILUSTRACIONES¦ ILUSTRA??ES
Removable tab
Languette
Leng?eta extracci?n
Alavanca usada para o rolo
Ink roller
Rouleau encreur
Tamp?n de tinta
Cartucho de tinta
English
Your Texas Instruments calculator has a built-in printer for producing a permanent record printout of
your calculations with negative numbers printed in red. A big, easy-to-read display also enables you to
check entries or perform quick calculations without printing.
GETTING STARTED
OFF ON PRT IC GT
POWER
1. Connect the calculator to a proper power outlet (110-120V or 220-240V
where available).
2. The calculator is turned on by setting the POWER switch to the PRT
position.
Inserting the paper (see illustrations 1, 2, 3, and 4 on page ii).
1. Turn on the calculator.
2. Open the printer compartment cover by pressing down on its front edge and sliding it back in the
direction of the arrow.
3. Fit the roll of paper on the holder so that it unrolls from the bottom, with the loose end toward the
calculator.
4. Cut the end of the paper squarely and insert it firmly into the printer slot on the back of the
calculator.
5. Press & until the paper is in the printing position.
Replacing the ink roller (see illustrations 5 and 6 on page ii)
1. Turn the calculator off and tear off the excess paper.
2. Remove the printer cover by pressing down on both sides of the front edge and sliding back in the
3. Remove the old ink roller by lifting it with the removal tab.
4. Insert the new ink roller into the compartment and press down gently until it snaps into place. Close
the printer compartment.
Note: The old ink rollers should not be refilled. Replacement rollers can be obtained from your local
retailer. The warranty does not cover ink roller replacement.
SELECTION SWITCH SETTINGS
OFF ON PRT IC GT
POWER ROUND
: 5/4 9 + F 0 2 3
DECIMAL
TAX
SET CALC
Set the POWER, ROUND, DECIMAL and TAX switches as required.
Note: The TAX switch is spring-loaded to return to CALC when it is moved to SET and released.
The switch settings are summarized in the following table:
SWITCH SETTING FUNCTION
POWER ON
PRT
IC
GT
No printout is provided; however, the display can be printed by pressing
4.
The printer provides a printout of your calculations but does not count them.
The printer is on and an item count of additions and subtractions to or from
the register is printed when sub-totaled or totaled.
The GT position controls whether or not the totals from the independent add
register are accumulated in the grand total register.
ROUND Rounds the result of a calculation to the selected number of decimal places.
5/4
9
Truncates the result to the selected number of decimal places.
Rounds the result up or down according to its value. For example, when the
DECIMAL switch is set to 2, the result is rounded up if the third decimal
position is 5 or more and rounded down if it is 4 or less.
Rounds the result up to the selected number of decimal places.
Ex. 220 P 6
Setup: PRINTER: PRT, ROUND: :
DECIMAL: 2, TAX: CALC
Ex. 220 P 6
Setup: PRINTER: PRT, ROUND: 5/4
Press Display Printout Press Display Printout
2 0. 0¦ C
220 ' 220. 220¦ P
6 3 36.66 6¦ =
36¦66 ?
2 0. 0¦ C
220 ' 220. 220¦ P
6 3 36.67 6¦ =
36¦67 ?
DECIMAL + Add mode: All results are given with two decimal places. For addition and
subtraction only, a decimal point is automatically placed to the left of the last
two digits entered, unless the number already includes a decimal point.
F Floating mode: Any results are displayed and printed with the maximum
0 2 3 4 Fixed decimal mode: Sets the number of decimals to 0, 2, 3, or 4.
TAX SET
CALC
Lets you enter a tax rate to perform tax calculations.
Stores the tax rate. Pressing ! or " after a tax rate has been entered,
adds/subtracts the stored tax rate to/from the value in the display.
Ex. VAT = 17.5 %
100 + VAT
Ex. VAT = 17.5 %
235 - VAT
Setup: PRINTER: PRT, DECIMAL: F, ROUND: 5/4, TAX: CALC
Move and hold the TAX switch to SET. Press 217 L 5 and release the TAX switch. It
automatically returns to CALC. 17.5% is printed.
2 0. 0¦ C
100! 117.5 100¦
17¦5 @
117¦5 ?
2 0. 0¦ C
235" 200. 235¦
N35¦ @
200¦ ?
Note: The most common setup is POWER: PRT, ROUND: 5/4, DECIMAL: 2, TAX: CALC. Use these
positions for the examples unless other settings are given.
KEY DESCRIPTIONS
Basic keys
I Clear Entry: Clears an entry, enabling you to enter another number in its place. Note
that this key does not clear the add register.
2 Clear Key: Clears the add register, any pending operations, and the display. 0.C is
printed. Does not clear the memory.
( Right Shift: Deletes the right-most digit entered from an entry before an operation key is
pressed. Shifts the remaining digits one place to the right.
L Decimal Point: Enters a decimal point.
4 Date/Non-Add: Prints a date (such as 12¦10¦96) or a number for reference purposes.
Does not affect calculations. This entry is printed on the left side of the printout, the date
or number preceded by the # sign.
& Paper Advance: Advances the printing paper.
Addition and subtraction keys
9 Add: Adds a number to the add register. Displays the cumulated result.
: Subtotal: Gives the intermediate total from the add register. Using this key does not
affect the contents of the add register.
. Subtract: Subtracts a number from the add register. Displays the cumulated result.
E Total: Gives the total from the add register, and then clears the register.
Multiplication, division, percent and margin keys
? Multiply: Multiplies the number in the display by the next value entered.
' Divide: Divides the number in the display by the next value entered.
3 Equals: Completes any pending multiplication or division operation.
> Percent: Calculates percentages, ratios, add-ons (e.g. of VAT), or discounts.
# Gross Profit Margin: Calculates the selling price of an item when its cost and gross
profit (or loss) margin are known; also used to obtain a price excluding VAT.
Ex.
Cost: 594
Profit margin: 40%
Press:2 594 # 40 3
Answer:
Selling price: 990
Gross profit: 396
Ex.
Selling price including VAT: 252
VAT %: 20%
Press: 252 # 20 . 3
Answer:
Selling price excluding VAT: 210
VAT: 42
/ Grand Total: Gives the grand total of the operations previously performed and stored in the
Grand Total register. Every time a total is obtained with E it is cumulated into this register
(printout shows G+) which is only cleared when / is pressed twice. During long
calculations, if / is not used, this re
Jan 16, 2011 | Office Equipment & Supplies
Whenever I try to add or subtract a number with a decimal in it, when I press the + or - key, it rounds the number I entered either up or down to the nearest whole number.
You have the calculator set to round everything in the display to zero digits after the decimal point. To change this, press SHIFT [DISP] and then a digit representing the number of digits you want to the right of the decimal point.
Nov 09, 2010 | HP 10bII Calculator
I want to increase the number of decimal places
I found this solution on the HP website. Turn it on, and do what it says. Then turn it off and back on again, and the extra decimal places should show.
http://h10025.www1.hp.com/ewfrf/wc/document?dlc=en&lc=en&cc=us&docname=bpia5183 Introduction This document describes how to set the desired number of decimal places on the HP 12C Calculator in standard format and in scientific notation. Instructions for standard format
  1. Press and release the gold PREFIX key (f).
  2. Press the number key for the desired number of decimal places (0 through 9).
The display will show the specified number of decimal places. The answer will be rounded to the number of digits selected.
Mar 25, 2009 | HP 12c Calculator
Pls. give me a code of scientific calculator
You caould have a series of buttons for the numbers, +,-,= and so on.
Put code in each button to increment and decrement the total (depending on if they press + or -) and display the total if they click =.
The key is to decalar the total as a global variable at the top on the form's code:
dim total as double
Making it scientific probably means to add exponenets into it, ie powers.
Add another buton called ^.
It would raise the value of total by that power of the next button pressed. ie. 3^3 = 27.
You would also have to handle decimal places.
Jan 03, 2009 | Casio fx-300ES Calculator
Excel Formula
columns total in additin cells of rows equal are total
Oct 24, 2007 | Oracle 10g Database Standard (ODBSEONUPP0)
Staples SPL-P100 Printing Calculator Logo
369 people viewed this question
Top Staples Office Equipment & Supplies Experts
gbob59
Marvin
Marvin
Vernon Taylor
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
