Question about Sony BM-850T Desktop Cassette Transcriber / Recorder
Transcriber will rewind and fast forward but when I push play, it just beeps and won't move.
Posted by Connie Chestnutt on
1 Related Answer
alawton96
SOURCE: Suddenly my Sony M-2000 Microcassette
Just talked to Exec. Communication Systems. He said that the play motor is not turning (the rewind and fast forward uses a separate motor) and the problem is either the belt or the motor. They can repair them at $82.00 plus parts and shipping.
Posted on Dec 03, 2012
How do i get a sony microcassette transcriber m-2000 to play/rewind/fast forward continuously?
Probably has a bad sensor belt (small belt attached to silver and black reflective wheel).
Aug 07, 2014 | Sony M-2000 MicroCassette Transcriber...
Microcassette won't play but does rewind and fast forward
I have the 3 of these units at my office with the exact same problem. Turns out, with a little tinkering there is a simple fix.
Open up the unit (by unscrewing the two screws underneath) and look for a brass disk with a black rubber band around it that connects to a small tip. The rubber band should be either stretched, broken, or even melted. This is the problem. Over time the rubber band deteriorates which causes the unit to not play a tape (rewind and fast forward operate differently).
Replace the deteriorated rubber band with a new one similar in thickness and size. That should work like a charm. Be careful if the original rubber band has melted. It is tar-like and will be difficult to remove.
Hope this helps.
Apr 14, 2013 | Sony BM-815 / BM815 Micro Cassette...
WON'T PLAY BUT WILL REWIND AND FAST FORWARD
Replace the deteriorated rubber band with a new one similar in thickness and size. That should work like a charm. Be careful if the original rubber band has melted. It is tar-like and it will be difficult to remove.
Hope this helps.
It won't play, rewind or fast forward.
Most likely the belt is broken or has jumped off. This requires some major disassembly, but the belts can be purchased for about $2. If the belt is okay, then check motor leads, they often break off.
Jul 07, 2011 | Panasonic RR-930 Desktop Cassette...
The dictaphone wont rewind or fast forward and makes a bleeping noise
Does the tape move when you press rewind or fast forward.
If the tape moves for a few seconds then bleeps it sound like a sensor problem.
If it only bleeps when the rewind and fast forward are pressed and the play is ok it sounds like the actuator motor is faulty,this motor enables the rewind and fast forward.
Hope this helps.
Dec 07, 2010 | Dictaphone 1740 Desktop Cassette...
Suddenly my Sony M-2000 Microcassette Transcriber will not PLAY. The tape will Rewind and Fast Forward fine, but when you push PLAY, it just beeps and won't move. Any ideas?
May 18, 2009 | Sony M-2020 Desktop Cassette Transcriber /...
Dictaphone Expresswriter 2740 Tape Won't Move
The problem is with the capstan motor. More than likely it has developed a 'flat spot' and won't spin up. The clicking noise you hear is the solenoids trying to pull the heads into place, but because the motor isn't turning, it can't pull the heads into place.
Mar 05, 2009 | Dictaphone 2740 Desktop Cassette...
Does not play. will rewind & fast forward
Its most likely the cam gear. Any sony dealer can replace the gear.
Jan 07, 2009 | Sony BM-87DST Desktop Cassette Transcriber...
Dictaphone 3750 transcriber
If it does this with all tapes, there is a small "no-cassette" switch at the back of the cassette compartment. The switch may be broken, dirty or out of adjustment. When you open the cassette door you should be able to see the switch tab. Push it in just a bit to see if the No Tape indicator goes out.
Sep 09, 2008 | Dictaphone 3750 Desktop Cassette...
Sony BM-850T Desktop Cassette Transcriber / Recorder Logo
217 people viewed this question
Top Sony Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
