Hi Shane, the two links below are youtube videos showing how to fix your spark plug hole......CHEERS..
Repairing Stripped out Sparkplug Threads
Rethreading Blown Spark Plug Hole Yourself
Helicoil it or the better Alcoa system
SOURCE: 2004 kawaski 750 vulcan motorcycle
if you plan to modify your exhaust system you will have to rejet your carbs to compansate. kits are availableat most aftermarket shops.
SOURCE: I need to know the spark gap for the spark plugs
My 2001 kawasaki vulcan 750 calls for 32-35 gap or0.8-0.9 mm
SOURCE: what are the correct spark plugs to run in a 2001 Vulcan 1500
NGK are the best plugs to run in a Kawasaki. For gaping instructions contact a dealer.
SOURCE: Changing Spark Plugs on 1999 Honda Shadow 750
Yes, it is an 18mm plug but you will need to use the Honda Plug Tool which is part of the stock tool kit just below the seat. Use that and you will get all of the plugs out very easily.
