Question about Fuji FinePix Cameras
My camera will not respond once switched on and I have to remove the batteries to switch it off. The batteries are full charged.
5 Related Answers
smc3
SOURCE: Battery life
I bought this type of camera a few months ago.  Instantly I noticed that is wears down batteries.  I would not get to take a lot of photos if I was on a vacation trip.  I have to keep the two batteries on a charger if I wanted to take many photos.  This is disappointing.  I have no solution for you.  However, if someone does have a solution, I, also would like to know it.
Posted on Nov 01, 2007
Anonymous
SOURCE: Canon Ixus 75 not charging
The camera was working fine 2 days ago. Yesterday when I tried to switch it on, I assumed that the battery was flat so I charged it but when fully charged the camera still won't switch on. Please help! bob
Posted on May 25, 2008
Anonymous
SOURCE: switching off as if battery is depleted when the battery is newly charged
I called Pentax and they said it's a known problem and the lens needs to be re-synchronized. They said this is usually caused by dust in the lens.
I have to send the camera to : -
Pentax U.K. Limited
Pentax House
Heron Drive
Langley
Slough
SL3 8P
It's a free repair if you bought the camera less than a year ago o/w they will send you a quote for the repair.
Posted on Oct 01, 2008
Anonymous
  • 734 Answers
SOURCE: Canon powershot SD750 will not turn on.
Hi
There are several things that could cause this.
1- Check the battery door indicator switch under the battery door and beside the memory card slot. Is the little black switch damaged or missing? Try pressing down gently using a pen it with the door open and then press the power button. Does it turn on?
2- The fuse has blown and needs to be replaced. Offhand I don't recall where it is on the SD750 PCB or how hard it is to solder on a new one (depends on if its tricky to get at or not). Good thing is fuses are really cheap.
3- Other power problem with the PCB due to corrosion or impact damage. The PCB or 'motherboard' of the camera will need to be replaced.
Posted on Dec 04, 2008
Anonymous
SOURCE: Camera is not switching on
I have an S610 that would sometimes not turn on or randomly turn off. I bought a replacement battery to see if that was the problem but no change. I noticed that if I firmly pressed the battery compartment lid the camera would operate fine, but wiggling the lid would make the camera turn off. I discovered there is a small lever inside the battery compartment that the lid depresses. So my solution was to attach something to the small plastic tab on the lid to help it depress the lever._357.jpg
Posted on Dec 28, 2010
I have a GC-XA2BU and the camera will not cut on? I have purchased a replacement battery but neither work.
As soon as you connect a camera to a computer, it will stop working, because the USB connection will be used to charge the battery.
If your computer is not correct wired on the USB port, or when you are using a hub, without an external power supply, the battery will not be charged. So you end up with an empty battery and a camera that does not respond.
Try charging the battery on an external charger and remove the USB cable, before switching on the camera. Also check if the USB connector on the camera is free. Avoiding the camera to "think" there is still a USB cable connected.
Feb 11, 2014 | Cameras
Kodak Camera DX 6490 is frozen in the open position and will not respond...open
Does not look good at all. Try this:
remove the battery. Charge the battery, or place another charged battery. Close the battery cover and switch the camera on.
I hope it now will retract the lens.
Most of the time you only can manage to freeze a camera with the lens in that position, when you remove the battery. That is unwise, because the camera does not know in what position the lens is, when you place the battery and switch on.
If the camera was switched out correctly and it could not retract the lens, it could be there is a mechanical problem in the lens barrel, or the motor (steering) is defect.
Sometimes camera's just die too.
I wide you luck while reviving your camera.
Jan 19, 2014 | Kodak EasyShare DX6490 Digital Camera
Turns off right after startup chime lens does not retract
This can happen when you use a battery that is almost without charge. Please remove the battery and charge it, before placing it back. Then be careful not to touch the lens, till the camera has a chance to retract it.
After you place the battery the lens should retract.
If the battery is really charged. You should not think it is charged, because you had it on the charger till the light indicated battery full.
There is also a chance you stopped the lens while it was coming out. A sensor detected this. To avoid damage to the lens construction, the camera switched off automatically. Also remove the battery and after a few seconds replace the battery and switch on the camera. Careful you don't touch the lens again.
Dec 26, 2013 | Sony Cyber-shot DSC-H5 Digital Camera
Not power off
I guess you can't switch the camera off when you are using it. But when you don't switch it off, the battery runs out.
After you charged the battery, what happened. Or next time, when it won't switch off, remove the battery, Then watch what happens after you reinstall the battery and try to switch it on.
If you can switch on the camera the switch is ok. If the camera starts immediately, after you inserted the battery, the switch is blocked. (makes full contact without you touching it). This is a real problem, and I think only can be repaired in the service centre. Please ask before what it will cost, because sometimes it is cheaper to buy a new camera.
Oct 31, 2013 | Samsung ST30 Digital Camera Pink
My camera will not power up at all, My Batery is full charged. Christmas is looming and I need a camera. HELPPPP!
Try this: with camera power switch in the "ON" position, remove the battery. Then press and hold the shutter release for approximately 30 seconds. Turn power switch "OFF", reinsert battery and turn back on.
Look on bottom of camera for a very small Hardware reset switch. If one ther, turn camera on and press for about 2 seconds.
Dec 21, 2010 | Nikon D40x Digital Camera
I keep getting the message: Turn the power off and on again. Just bought the Cybershot DSC-W370 tonight and it worked fine, until the battery was charged. ???
Why don't remove the battery? First, switch off the camera then remove the battery. Wait for 5-10 mins then put the battery back on and charge it straightaway. remember to leave the camera off while charging. let it charge full then unplug and switch the camera back on. let me know if this works for you.
Jun 26, 2010 | Sony Cybershot DSCW370 Digital Camera
Hi
Nov 21, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Smasung D75 Digital Camera
Remove the battery first and leave it turned off for half hour reconnect the battery and that should reset the camera and it should work.
May 22, 2008 | Cameras
Help!!!
did u try removing the batteries? try that first then put it back again. Its like resetting the camera. please dont forget your rating .thanks
Jan 25, 2008 | Fuji FinePix A600 Digital Camera
Cameras Logo
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Rob Hill
Rob Hill
Are you a Fuji Camera Expert? Answer questions, earn points and help others
