Coby MID8042-4 - Kyros MID8042-4 8 4 GB Tablet - Wi-Fi - Logo
l
lisa werkmeister Posted on Apr 06, 2016
How do I set up My email after I forgot My password?
How Do I reset email password
  1. Visit the email Forgot Password page.
  2. Select Password.
  3. Enter your full email address and your last name.
  4. Select Continue.
  5. From the drop-down menu, select I'll answer my security questions.
  6. Answer the security questions that you set for your account.
  7. Select Continue.
  8. Add a new password
  9. Select Enter
  10. Done. Your password will be reset successfully.
For email related errors and issues, the easiest way is to reach Email technical support service. Their experienced support team offers an instant solution and help for email setup and password related issues.
Dial directly toll-free number 1888-315-9712
email technical support number
My irulu tablet will not let me open screen without pin#. I was not given one
If it's an android device...
1. Enter wrong pattern 5 times and wait for 30 seconds.
2. Select "Forgot pattern" and enter your email account username and password.
3. Make sure you use the same account that was used to activate the device and double check the password by logging in to that email account in a browser.
4. If you don't have access to the original email account, you will need to do a hard reset and loose your settings and apps on the devcice. The data on the memory card will not be wiped though.
Note: if you can't remember your email password, you will have to visit the email service support page to get it reset.
also, see here...
http://www.androidtablets.net/forum/android-tablet-usage-tips-tricks/6280-forgot-your-unlock-pattern.html
or here... http://mytabletguru.com/forgot-password-pattern-unlock-of-android-tablet/
Good luck.
3answers
Forgot home screen password for Samsung 12.2 tablet. How do I unlock it?
also, see here...
My big lots tablet is lockedand i cant remember the pin itsa d2 7in.what can i do ?
also, see here...
My daughter put a lock on her tablet but forgot the code and does not know the password to the email it was set to
What email-provider was the email sent to? Maybe you can recover the account password with another email-adress, that was put in for recovery? For example: in Gmail you can put an recovery email-adress or a phone number and get your password reset that way.
Password unlocker
go online to your account, settings, first choice is forgot password. The next screen will ask for your email. They will probably send you and email with instructions.
Forgot email an password
click forgot password. should ask you questions then send password and email/ username to your email address
Sep 27, 2013 • Nabi 2
6helpful
Password forgotten kidzstar tablet
If you're connected to WiFi, you can tap the link for 'forgot password' and then an email will be sent to your email address. If you're not connected to WiFi: There are three options when selecting the option to enter Parent Mode: Select Age Group; Parent Controls; Device Settings, select Device Settings Enter the password 1orEnt= The password is case sensitive. Once in the settings, you can turn on the WiFi. Return to Kidz Mode and try to enter Parent mode, tap Forgot Password. If you don't receive the email, again enter Device Settings, from the left select Apps, on the right select ALL from the top bar. Scroll down the right hand pane and select Kidzstar Mode, from the right hand pane select Clear Data. Return to the idle screen and switch off the unit. When you turn it on, you will need to set up a new account with a different email address.
Top Coby Tablets & eReaders Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you a Coby Tablet and eReader Expert? Answer questions, earn points and help others
