Question about HP LASERJET P1006 Printer
Roller cannot pull up the paper from the paper tray.
Posted by Fisher Young Dinh on
guruaid_cs
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 906 Answers
To help you troubleshoot the issue paper does not load on the roller, please find the link below:
http://support.hp.com/us-en/document/c02016130
If issue persists, check if printer is under warranty. To check these please find the link given below:
http://support.hp.com/us-en/checkwarranty
If the printer is out of warranty, please contact HP Service Center for servicing the printer:
http://h20566.www2.hp.com/portal/site/hpsc/public/help/contactHP/home?ac.admitted=1459920815636.1123376534.199480143
GuruAid.com
Posted on Apr 06, 2016
How do i clean the rollers on my printer?
Paper Tray Rollers Step 1 Turn off and unplug your HP printer. Pull out your printer's paper tray and locate the printer rollers on the paper tray. Each roller is gray or black, and they are made of rubber. Remove the rollers from the tray.
On HP inkjet printers, the printer roller is not on the paper tray; it is on the area inside of the printer where the paper tray slides into the unit. Remove the paper tray and sit your HP inkjet printer upright, so the paper tray area is facing upward, and then look for the printer roller.
Step 2
Pour 1 tbsp. of isopropyl alcohol or clean water onto a lint-free cloth and scrub the paper or internal tray rollers with the cloth. Fold the cloth in half and repeat the cleaning process until the rollers are free of dust and debris.
Step 3
Wipe the rollers with a dry, lint-free cloth to remove any remaining dust or debris. Let the rollers dry completely before sliding the paper tray back into your printer.
Internal Pickup Roller - Laser Printers Only Step 1 Turn off and unplug your HP printer. Open your printer's front door and pull the printer's toner cartridge toward you to remove it from the printer.
Step 2
Locate your printer's internal pickup roller. The roller is gray or black, and it is made of rubber. Lift the roller upward, towards the front of your printer. Pull the roller gently out of the printer and lay it on a clean surface, such as a desk or workbench.
Step 3
Pour 1 tbsp. of isopropyl alcohol or clean water onto a lint-free cloth and scrub the pickup roller with the cloth. Fold the cloth in half and repeat the cleaning process until the roller is free of dust and debris.
Step 4
Wipe the roller with a dry, lint-free cloth to remove any remaining dust or debris. Let the roller dry completely before snapping the pickup roller back into place inside of your HP printer. Reinstall the toner cartridge and close your printer's door.
Aug 10, 2014 | Dell 1720dn Laser Printer
Hp3005 had a paper jam tray two, pulled out paper, now tray 1 keeps running pulling paper but doesnt print.
You have a pick up roller that needs replaced. If you pull the tray out, take a flashlight and look up into the printer. You will see a black roller. It probably is covered with white paper dust and slick looking. This needs replaced. That is all that is wrong.
Jan 03, 2014 | HP LaserJet P3005n Printer
I removed a jammed sheet of paper through the front opening, Had to pull real hard. Since then, when printing or copying, printer feeds up to 4 extra sheet with each printed page. I suspect some piece of...
Please see this solution from Canon. It is recommended you check your manual for the proper procedure for clearing paper jams. Incorrectly removing jams could damage your printer. Trust the following helps resolve your current issue.
If you do not have a manual it can be downloaded from here:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx300#BrochuresAndManuals
Issue: More than one sheet of paper feeds while printing
Solution: Clean the paper feed rollers using the MX300 operator panel
sikaku.gif Cleaning the Paper Feed Roller (Roller Cleaning) Clean the paper feed roller if paper is not fed properly. Cleaning the paper feed roller will wear the roller, so perform this only when necessary.
1. Make sure that the machine is turned on, and then remove any paper from the Rear Tray.
2. Clean the paper feed roller.
(1) Press the Menu button repeatedly until MAINTENANCE appears.
(2) Press the l_mark_s.jpg or r_mark_s.jpg button to select ROLLER CLEANING, then press the OK button.
The paper feed roller will rotate as it is cleaned.
3. Repeat step 2 twice.
4. Open the Paper Output Tray.
(1)Put your finger in the rounded indent beside the Paper Output Tray and open it gently.
(2) Open up and set the Output Tray Extension completely by pressing down the hollow on its front side.
5. Make sure that the paper feed roller stops rotating, then load three or more sheets of A4 or Letter-sized plain paper in portrait orientation in the Rear Tray.
Set the Paper Thickness Lever to the left.
6. Repeat step 2 three times.
The paper cleans the paper feed roller as it feeds through the machine.
If the problem is not resolved, wipe the paper feed roller (A) located on the right side inside the Rear Tray with a moistened cotton swab or the like. Rotate the roller (A) manually as you clean it. Do not touch the roller with your fingers; rotate it with the cotton swab.
Dec 25, 2010 | Canon MX300 Office All-In-One Printer
Paper jams every time
Have you tried printing a page from the hand feed tray ( if you pull down the front door you can feed it thru there.) take the paper out of the internal paper tray
Oct 28, 2010 | HP LaserJet 1320 Printer
It say error JAM 1 what does that mean
Look inside printer to see af any paper is in there if so remove.Pull out paper tray and clean pickup roller (roller that picks up paper from tray)if the roller has film on it it will cause jam1 error
Mar 22, 2010 | Dell 1600n All-In-One Laser Printer
I cannot print from tray 2. i mean it doesn't pick my paper at all
Double check the driver settings, and be sure the default setting in the printer properties is tray 2. After that, post more detail to help resolve it.
Dec 24, 2009 | HP LaserJet P4015N Printer
Ruppled printed paper cannot exit output tray
you need do follow steps:
1) check fuser unit, the fuser hot roller is hot or not? if not the fuser heater fail.
2) check hot roller should spin with the pressure roller which is against hot roller, and check there is no gap between them, and also nothing pieces paper obstruct there, because if it losts pressure balance that jam should be occured there.
3) check the output roller after fuser unit(if there is), check them are spin or not, this roller kit use for pull the paper goes out the tray. if not spin means the roller drive belt or gear loosen.
3) check paper sensor that is micro swtch around pulling roller or output area and to clean it (could be a optical sensor).
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
May 25, 2009 | Samsung ML-2510 Laser Printer
Mfc-665cw all in one paper tray
To get the paper tray out, remove the rear "door "from the all-in-one (and "carefully" lift the roller guide out of the way. Sometimes a finger works, but a pen is guaranteed to work. When the roller guide is out of the way the tray slides out verrry easily. When its not, the tray is nearly impossible to get out!
Note that the right-hand side of the tray has two inclined guide "ramps" that work as the tray is removed. Once you get the tray out place a "small!" amount of petroleum jelly on the rear ramp: works like a champ.
Oct 11, 2008 | Brother MFC-665CW All-In-One InkJet...
OPTRA T610 NOT PRINTING FROM TRAY1
What happens is that the rubber roller that's supposed to pick paper up and load it in doesn't pull the paper from the tray anymore, hence it gives the paper jam error message. If you want you can replace that rubber roller to fix the problem, however first thing I do is to take that rubber roller out (remove tray and look underneath to find the roller) and turn it inside out then fit it back. This will give the rubber roller the grip that it missed and solve your problem.
Jul 13, 2008 | Lexmark Optra T610 Laser Printer
HP LJ1200- won't pull from Envelope\Manual Feed tray
Ensure that you are putting the paper in the right position.
there has not been problem of pick of roller from that model.
Ensure that paper are well inserted into the printer.
You can clean the pickup roller. worn out roller might be responsible.
Feb 25, 2008 | HP LaserJet 1200 Printer
HP LASERJET P1006 Printer Logo
Ekse
efs_perpends
efs_perpends
