ASUS VH242H : VH242H 23.6 inch WideScreen 5ms 20000:1 DVI/HDMI LCD Monitor w/ Speakers Black : MONL511 Logo
Paul Ouellette Posted on Apr 04, 2016
How do I adjust the monitor so I am able to view everything full screen. Right now, there is a 1 black margin around the viewable area.
shirin2000
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 11, 2016
shirin2000
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
174
Points
You can rigt click and choose full screen
an d see my site : http://banehcoolers.com/
  • Anonymous Jun 26, 2017
    its ok.see my site about Splithttp://banehcooling.com
My HP optical mouse goes beyond the viewable area on my HP monitor (but just on the right side).
should just have to use the buttons on your monitor to adjust the width of the screen or maybe move the screen to the left.
2helpful
1920x1080 resolution-entire screen not viewable
This also happens to my vga connection to my TV.
I used my tv remote "auto" button to re-size it to fit correctly.
If your monitor/TV does not have the adjustment, you may need to
supply your vga compatible device with your monitor's driver software.
This tells your computer what monitor specifications you have.
Compaq mv540 monitor suddenly can't adjust screen features
Please somebody give a solution as same is experienced by me tooo.
The monitor is giving a zoomed in view . its not giving the full view of the desktop screen rather a section of it is zoomed in . there are no settings to zoom out .??
ur setting may be set to low resolution...
try doing this
go to Desktop/right click/properties/Settings/Screen Resolution/
What do u c...what's the resolution there...800x600...
if the slider(pointer) is active use it to increase it to say 1024x768, 1152x864, 1280x1024 etc.
use the correct resolution....as too much of resolution will make ur monitor un-viewable...
also try if ur monitor has some press button on them to make changes to the correct setting/zooming of the screen image...
A 1/2
there are 2 possibilities 1. you have changed screen resolution by accident, try using that [right click desktop and properties, look in tabs there] or 2. your screen is old and it has "burned out" in some parts
The viewable area is bigger than the screen. I
You probably need to go into the control panel and change the resolution for your display
Compaq Monitor Model 7600
There are usually controls, button or knobs, to "Stretch" "Move" "Pincusion" and others... have you tried this, as this is what it "Sounds" like to me from ya description? If there are NO controls on the front to accomplish this task, at the REAR of the unit there should be controls marked to show the function. Below is a link where ya will find a Manual that may help ya. http://www.retrevo.com/s/HP-7600-Monitors-review-manual/id/281ci552/t/1-2/
Acer 19167W flat screen
Depending on the application you are viewing the picture in you can shrink the application window. You could reduce the size of the viewable area but that defeats the purpose of the wide screen which is to provide a better viewing experience (to quote the marketing types). It sounds like....since the wider screen really has nothing to do with your picture size....you might want to adjust your picture size independent of screens and applications. There are a variety of free products out there that can do this...and some are really nifty...perhaps better than the software you might now be using.
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
