It sounds like your Tag Carrera automatic watch may be experiencing an issue with the automatic winding mechanism. Here are a few things you can try to troubleshoot the issue:
Make sure that the watch is fully wound. If the watch is not fully wound, it may not have enough power to keep running.
Check the balance wheel and pallet fork for any debris or obstruction that could be preventing the watch from running.
Inspect the winding rotor for any signs of damage or malfunction. The winding rotor may need to be replaced if it is not functioning properly.
Check the control panel for any error codes or messages that may indicate the cause of the issue.
An automatic watch receives it power from the mainspring, which is wound by hand (most watches) and from movement of the arm which causes the Oscillating Weight to spin around and wind the mainspring. The problem is that it takes many, many rotations of the weight to put enough winds on the mainspring to keep it going. If you have not worn the watch for 24 hours you need to put initial winds on the mainspring, either by turning the crown or by swinging the watch around 30-40 times. If the watch is in good mechanical condition, once you put the initial winds on it, you can put it on your wrist and it should run overnight if taken off. Most older Seiko watches cannot be wound by hand.
It looks like your watch has mechanical issue. Without inspecting the watch it's hard to say what exactly the problem is and I suggest you return it for replacement under warranty.
Yes, the Movado is a self winder, and it was designed for the sports active wearer, of which the motion of the wearer's arm provides the power to keep the watch wound. Apparently you are not active enough for the watch to be fully wound, so when you take it off, it will use up all of the stored energy in the spring and stop. many self winders will only store enough energy for 8-12 hours of use and will require constant wearing. You could try wearing it to sleep and see if this is enough to keep it wound.
If you feel that this is not the case for your watch, then you may want to have it looked at by a watch maker
mcdevito75 here, Generally your Cartier watch is wound in a clockwise direction simply, due to how it:s made, in this direction the mainspring is tightened or wound and turning the crown in a counter-clockwise position only free wheels the winding mechanism. I would advise you wind your watch in a multi direction, however not to the very, very end of It"s winding capacity, once you feel the crown getting tension only 4--5 more multi-direction turns should be enough to maintain a good wind to your Cartier watch.
An automatic watch needs to be worn, wound daily or placed on a watch winder to keep it going. It is not like a quartz watch that has a battery and can keep going when not worn. A modern automatic watch will run for about 36 - 48 hours on a full wind.
A quartz watch that stops like you describe is in need of a cleaning by a professional watchmaker. When this stopping occurs it is an indication the oils have dried out and the warmth from your body heats them so they are semi liquid again and the watch runs. but when the watch cools again the oils harden and the watch stops.
Hope this helps,
Ken Yellowstone Watch, Inc. www.yellowstonewatch.com
This is a mechanical auto-wind watch. It self winds when worn. But if taken off for a couple of days it will have stopped and won't start running again unless it is wound.
Put it on and wear it for a few minutes. This will wind it enough to start it running again. Then set the time and wear it and you'll be fine.
Hope this helps. Ken Yellowstone Watch Inc. www.yellowstonewatch.com
You can wind this watch until it is snug. If it does not continue to run during normal wear then you should have the watch looked at. The swing weight or main spring maybe malfunctioning. If you can return it under warranty that would be best.
