SOURCE: lost radio code pls help me BP 7 649372 316
Insufficient information.
Please also quote the 14 character serial number beginning with
BP++++++++++++ or similar ...often found stamped in the metal casing.
Also quote the MAKE of CAR
SOURCE: I need a security code
Hello Jakes Jacobs, sorry but there is usually no way to get security codes for radios online. If getting it online were possible it would make the point of putting the codes there in the first place void. The only way you can get the genuine code is if you get the unit to either the nearest blaupunkt dealership or the car dealership from which the car was gotten. When going there go with a proof of ownership and a valid ID. Sorry for any inconveniences.
Thank you for visiting FixYa.
SOURCE: 2000 Holden Astra - Hi there, I require a radio
If you have removed the radio from the car or changed/disconnected the car battery sometime back then you need Jaguar radio unlock code to get the sound back. You can purchase it from here.
There are few ways to unlock the radio
1. Refer to your manual. You must be having the code as well as the procedure to unlock it.
2. If you do not have the code then you can purchase it online. You will get the code within a day. For that you have to collect 2 information.
a. VIN - Vehicle Identification number, usually found at the bottom of the driver side windshield.
b. Radio serial number. You can get it on the top of the radio after removing it from the car.
c. You can purchase the code from here.
SOURCE: NEED A RADIO CODE FOR ALFA ROMEO BP 037834830471
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your Alfa Romeo service centre and get them to enter this code for you.
