Question about Ademco Home Security
While programming my one of the keypad ademco 6151 does not respond. I pressed * and then # sign it just showed me the keypad number18 and then E1. How can i bring it back to life.
Panel is ademco/ vista 15p.I was trying to install envisalink 4 while doing the programming my security system just stopped taking any keys or numbers. Please help , no experience in IT.
Posted by Suman Kohli on
Roy McCracken
    New Friend:
  • 59 Answers
Check wiring, if the yellow wire is broken/ loose, it will "lock up" the keypad
Posted on Jul 03, 2017
5 Related Answers
Anonymous
  • 10 Answers
SOURCE: Programming of Ademco 5839
Program the house id to 8 And enable all keypads
Posted on Jan 21, 2010
Anonymous
SOURCE: I just bought 2 ADEMCO 5804 Key Fobs for my ADEMCO
yes i can help you who monitors ur system because your gonna need the installer code to get into programming or power down the sytem then hold down the *and # to get into programmming
Posted on Feb 04, 2010
Jeremy Nichols
  • 20 Answers
SOURCE: need a manual for the
This site has manuals for the 6160 keypad, and the 15P and 20P panels.
http://www.avss.net/manuals_books.htm#how
Hope this helps.
Posted on Mar 01, 2011
steve_hillin
Steve Hillin
  • 44 Answers
SOURCE: I have 3 ademco keypads on my system. The system
This means that the alarm panel's backup battery is either bad or not connected. These batteries provide power for the system in case of a power outage and are essential for a solid alarm system. Look inside your control panel box ( usually in the master bedroom closet ) and see if the battery connection is just off or if the battery is missing. If it is connected, it is probably too old and needs replacement. Contact your local alarm company and they can swap out your battery or provide one for you.
Posted on Mar 05, 2011
Sean
  • 80 Answers
SOURCE: why FC show on ademco
FC is for faliure to communicate. Need to check systems connection to monitoring station. Did anyone work on your phone line(s) or did you change your phone company or service? GL.
Posted on Apr 23, 2011
Vista 20p momentary sounds alarm when system is armed why is this?
It can be disable in installer level programming. It is called confirmation of arming ding. It is so you know that your system is arming when you use you keyfob from outside of your house.
Mar 04, 2014 | Honeywell Ademco 6160 Alpha Keypad Vista...
What is a long range radio trouble
It indicates a problem with your cellular radio or that your alarm system is programmed to look for one that is no longer working or connected to your system. This can be disabled in installer level programming.
Aug 21, 2013 | Honeywell Ademco 6160 Alpha Keypad Vista...
Can't access installer code honeywell vista 20p
Power down the panel, remove the battery. Hold down the * and # while re-powering the panel. It will jump right into programming. Release the *and # button and proceed with programming.
Apr 07, 2013 | Honeywell Ademco 6160 Alpha Keypad Vista...
The LCD says : 20. No AC,what can I do?
Check your transformer your secondary might be bad.
Jan 22, 2013 | Honeywell 5828V - Ademco Wireless Talking...
Ademco security system still doesn't chime when press 9 key
You need to enter your 4 digit code first. Make sure you do it half way quick.
Oct 24, 2012 | Honeywell Ademco 6160 Alpha Keypad Vista...
Trying to get installer code on Honeywell Vista 15-P
hit *20 then put in whatever 4 digits you want as installer code. write this down on your program sheet for future reference. yes, you should have a program record sheet to follow and know how to navigate in programming or else you could make things worse.
Jun 29, 2012 | Honeywell Ademco 6160 Alpha Keypad Vista...
My Honeywell Ademco 6160 Alpha Keypad Vista 10E low battery light keeps flashing even after I've change out????
The low battery light will stop flashing when the new battery you just installed become fully charged. It will take some time for the new battery to become fully charged.
Jun 06, 2011 | Honeywell Ademco 6160 Alpha Keypad Vista...
How do I program zonig for my Ademco 6148 pad
The 6148 keypad is a fixed english keypad. It is possible to program your system from a fixed english keypad, but it is very difficult. an alpha keypad shows text descriptions of the programming fields. The model number is 6160. If you are doing your own programming, I would suggest replacing the 6148.
When programming, you're programming your alarm panel, not the keypad. The keypad is just an interface to the panel. If you have a tan box in your basement or a closet, that is your panel. There will be a sticker on the inside of the door of the panel that will tell you the model of the panel at the bottom. It will say Ademco Vista 10, 15, 15P, 20, or 20P.
From there you can go to the link below and find the installation and programming manual for your panel.
http://panelguides.com/panel-guides?task=viewcategory&catid=521
Hope this helps.
Mar 18, 2011 | Ademco 10) Ademco 6148 Keypad Fixed...
6160 key pad "open circuit"
open ckt on the keypad refers to the data lines going to the keypad. check to make sure the yellow and green wires from keypad are properly connected.
Feb 17, 2011 | Honeywell Ademco 6160 Alpha Keypad Vista...
How do you enable the visible exit countdown on the vista series?
Get into programming then enter # 197. If you get a zero and a beep, enter *1971 then get out of programming. This will work on vista-15p, vista-15psia, vista-20p, and vista-20psia panels
Jan 02, 2010 | Honeywell 5804 Ademco Wireless Security...
Home Security Logo
370 people viewed this question
Top Ademco Home Security Experts
Sean
oooga boooga
oooga boooga
Level 1 Expert
Vincent Migliore
Vincent Migliore
Level 1 Expert
Are you an Ademco Home Security Expert? Answer questions, earn points and help others
